who makes replacement steering shaft coupler? #1537929
11/21/13 08:01 PM
11/21/13 08:01 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
i have an 88 150 ram 4x4 purchased it for my son..
I need to replace the steering shaft coupler/universal joint.
its sloppy..not the rubber disk...the actual joint the attaches to the steering box.
who makes a new one?
also does anyone know what range of yrs the part is the same...as an 88 model.?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: who makes replacement steering shaft coupler? [Re: cheapstreetdustr] #1537930
11/21/13 08:08 PM
11/21/13 08:08 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
You can buy a kit to replace the internal parts of the coupler for about $10.
There's a how to here.
http://ramchargercentral.com/articles/?sa=view;article=85
People say the 4x4 trucks tend to wear the coupler out pretty quick for some reason though, so many people go to a u-joint style shaft made by Borgenson for about $200.
http://www.borgeson.com/xcart/catalog/7993_Full_Size_Dodge_Truck-p-1452.html
I'd like to get a Borgenson, but I rebuilt the couplers on 2 trucks so far and it helped the sloppy steering a lot.
Re: who makes replacement steering shaft coupler? [Re: 440newport] #1537931
11/21/13 10:06 PM
11/21/13 10:06 PM
i had a rebuild internal guts kit...i installed it a few yrs back on this truck for the owner....it arleady sloppy again..(actually its been about 5 yrs..but he had a gravel potholed driveway..
im ..thinking its the cast piece worn out..
i may do the borgenson deal...and be done with it.
[image][/image]
Re: who makes replacement steering shaft coupler? [Re: cheapstreetdustr] #1537932
11/21/13 10:14 PM
11/21/13 10:14 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
could this be why my steering shaft feels loose coming out of the column? sorry to hijack the thread
Re: who makes replacement steering shaft coupler? [Re: cheapstreetdustr] #1537933
11/21/13 10:26 PM
11/21/13 10:26 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I put a Borgeson shaft on my truck 11 years ago...got tired of the coupler rebuild every two years. Never touched the Borgeson and it's still as tight as a drum. Just spend the $250 and be done with it.
Mopar shoulda been shot for that BS design they had...
Re: who makes replacement steering shaft coupler? [Re: superwrench] #1537934
11/21/13 10:32 PM
11/21/13 10:32 PM
440newport Offline
440newport  Offline
I don't get why the truck ones wear out so fast though, and the car ones usually seem fine even on a 60's Mopar? It's not like it's any harder to turn the steering wheel on a truck with power steering than a car.
Re: who makes replacement steering shaft coupler? [Re: 440newport] #1537935
11/21/13 10:45 PM
11/21/13 10:45 PM
superwrench Offline
superwrench  Offline
On mid 70's trucks, that coupling was just below the steering column...the "rag" joint was down at the box. It just made a lot more sense that with the coupling up high, it wouldn't wear out because of all the crap from the highway getting into the joint. My old Ramcharger (75) had the rag joint at the box. Never wore out.
Re: who makes replacement steering shaft coupler? [Re: superwrench] #1537936
11/21/13 11:57 PM
11/21/13 11:57 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: who makes replacement steering shaft coupler? [Re: 340SHORTY] #1537937
11/22/13 08:24 PM
11/22/13 08:24 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
There is boot w/2 hose clamps & it's a mopar part that works wonders
Re: who makes replacement steering shaft coupler? [Re: 500ciDuster] #1537938
11/22/13 10:30 PM
11/22/13 10:30 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Do a search over at RCC for an article about building your own "Borgeson" shaft from a couple of pieces from pull-a-part. Did something similar for a Samurai I built a while back and it worked great.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: who makes replacement steering shaft coupler? [Re: I_bleed_MOPAR] #1846881
06/11/15 09:15 PM
06/11/15 09:15 PM
Wisconsin
beecrazy69 Offline
beecrazy69  Offline
Wisconsin
Gonna resurrect an old thread!
I see Dorman makes a new coupler end but it is listed as 79-87.
I have a 91 and trying to figure out why it doesn't go up to a 93?
It appears that the Borgeson shaft is listed for 79-93, so one would assume the splines on the box is the same....
Anyone know what is up with this?
Don
P.S. If the Dorman one is going to work, I think I will put a grease zerk on it.
