parts for 72 dart drum to disc conversion??? #1846634
06/11/15 02:48 PM
06/11/15 02:48 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
im collecting parts to do a 72 dart front drum to disc brake conversion. i have the following 74 dart upper a-arms,spindles,and backing plates.where is best place to get new a-arm bushings,ball joints,rotors,calipers,brake hoses and proportional valve for disc,and master cylinder????thanks guys
Re: parts for 72 dart drum to disc conversion??? [Re: hp340nos] #1846652
06/11/15 03:13 PM
06/11/15 03:13 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
also do i need the offset a-arm bushings for upper a-arms or can i use the non offset bushings
Re: parts for 72 dart drum to disc conversion??? [Re: hp340nos] #1846672
06/11/15 03:43 PM
06/11/15 03:43 PM
CA
crackedback Offline
crackedback  Offline
CA
Rockauto tends to be the lowest price, especially if it all ships from one location.
I've also used amazon to get parts.
Re: parts for 72 dart drum to disc conversion??? [Re: hp340nos] #1846710
06/11/15 04:48 PM
06/11/15 04:48 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
I used the lightweight aluminum MC from Rick Eherenberg. I used the offset bushings, but they're not really necessary. I got a used prop valve, but I believe they are available from Inline Tube (???). The rest of the parts came from NAPA.
Earning every penny of that moderator paycheck.
DBAP
Re: parts for 72 dart drum to disc conversion??? [Re: hp340nos] #1847127
06/12/15 01:25 AM
06/12/15 01:25 AM
not an absolute but I would suggest using them.
Re: parts for 72 dart drum to disc conversion??? [Re: hp340nos] #1847143
06/12/15 01:55 AM
06/12/15 01:55 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Disc brakes don't use backing plates??? Also what bolt pattern does the disc that you will use have? You rear axles are 4 inch aren't they?
Re: parts for 72 dart drum to disc conversion??? [Re: 71birdJ68] #1847147
06/12/15 01:58 AM
06/12/15 01:58 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i said backing plates,meant dust shields,front will be 4.5 bolt circle,back will be 4.5 also.
