73-76 Sway bar
#1846536
06/11/15 12:10 PM
06/11/15 12:10 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Any one try the 73-76 Hotchkis front sway bar and use the factory lower control arm tabs instead of the ones that come with the kit? I was looking at one last night and it looks like it should fit the stock tabs. It would save grinding off the tabs and welding the new ones on.
A new iron curtain drawn across the 49th parallel
Re: 73-76 Sway bar
[Re: 67autocross]
#1846987
06/11/15 10:51 PM
06/11/15 10:51 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
Yes I run a hotchkis with factory 73_76 A-body arms. First one they made for that. Google image search: autoxcuda hotchkis swaybar and you should see a picture of it.
Re: 73-76 Sway bar
[Re: autoxcuda]
#1847021
06/11/15 11:19 PM
06/11/15 11:19 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
I have a Helwig on my 73 wagon. It was a bear to install.
Abe Lincoln
Re: 73-76 Sway bar
[Re: 67autocross]
#1847119
06/12/15 01:16 AM
06/12/15 01:16 AM
67autocross
Manitoba Canada
This picture? Looks like the stock brackets will work. I had 2 cars at my place yesterday one with factory tabs and one without. Of course it was the car with no factory brackets that was getting the sway bar.
