Re: 56 dodge pickup info ?
[Re: Jupiter331]
#1846381
06/11/15 01:09 AM
06/11/15 01:09 AM
Posts: 10,625 Freeport IL USA
poorboy
Freeport IL USA
What kind of parts? Body? Good luck, very little is being made. Rear fenders fit through 82 or whenever the ended the step side boxes. Bed parts are also available that fit the "newer" beds, but things for specifically 54 -57 are pretty scarce. Mechanical parts are available, for the most part. Specific original style parts are available at: www.robertsmotorparts.com and Kanter automotive and a few other sources like www.vintagepowerwagons.com Try a Google search for specific parts. Don't over look O'rilley's or NAPA. Disc Brake conversions are available at www.rustyhope.com and others. Unfortunately, there is not one site that covers everything, but there is a lot of info about these trucks available on line, and we can answer more specific questions. Gene
[Re: Jupiter331]
#1847014
06/11/15 11:14 PM
06/11/15 11:14 PM
poorboy
Freeport IL USA
The original front suspension was leaf springs and a beam axle under the springs. If you are not using the truck to haul stuff, you can remove several leafs from each front spring pack (think every other as the most you can remove). You may also be able to move the axle to the top of the springs instead of having them under the springs, but this will require some modification to the axle itself, as well as new U bolts. You will also watch for oil pan clearance and axle to frame contact on downward bounce.
Power steering is different story. You will have to adapt a steering system from a different vehicle. Nothing fits without some modification.
Another option is to clip the front frame with something more modern. Some clips are more difficult then others, all require fabrication skills. A few options are a 90s-2000 something Crown Vick subframe. The Crown Vick has a bolt on front suspension. You will have to fabricate the frame contact points to bolt it to your truck. The Crown Vick is a bit wide and will put the tires right at the edge of your fenders. The Crown Vick has the 5 bolt on 4 1/2" center bolt pattern for wheels.
A second clip would be one from a Dakota pickup. This one you cut off your frame and weld in the Dakota frame. You will have to fabricate radiator and front fender location points, and newer then 1991 will have 6 bolt wheels, 1987 - 1990 are 5 bolt 4 1/2" pattern. The Dakota has about the same wheel width as your truck, unless you get carried away with the wheels. There are other clip options, each have both benefits & challenges.
I had a 54 twenty years ago that I put a Volare clip on. Great driver, nice ride,great brakes, but kind of "soft" suspension and a lot of work. My 54 sat low. the front edge of the running boards had about 4" of clearance. The bottom of the front bumper was scrapped up real bad, and i bent the front of both running boards several times, and I was careful! Low looks cool, but is a pita to drive a lot (we put 40,000 miles on it in 6 summers!) The 54 was the last low vehicle I've built! Gene
[Re: dogdays]
#1852289
06/19/15 12:45 AM
06/19/15 12:45 AM
poorboy
Freeport IL USA
From what I've heard from the old timers (and I'm 58) that if you think that flathead 6 crank is soft, most other cranks were even more soft.
One guy told me when the junked motors, they got more money out of them if they broke the cranks. They would set the cranks up on rocks, and throw other cranks at them to hit in the center. They could bust 4 or 5 GM 6 cylinder cranks with 1 Mopar crank before it would break.
Remember, back in the 50s, a 60,000 mile motor was basically wore out, very few motors ever saw 100,000 miles (even as late as the early 70s).
Back to the subject at hand, the 50s Dodge trucks fit nicely on a Dakota chassis. Shorten the Dakota wheel base to match the 50s truck, and swap the cab, box & front sheet metal. If your really into it, you can even use the Dakota floor pan & firewall. Gene
