painting the factory way or not???? #1845822
06/10/15 04:05 PM
06/10/15 04:05 PM
mr norms avenue
5571 Offline OP
5571  Offline OP
mr norms avenue
Ok, I learned the way an ebody was painted originally, it was all assembled.
How many people restore a car this way? My painter can do it either way, but he was going to shoot single stage underneath (all blue) and in the trunk and engine compartment, if painted all apart. He would 2 stage everything else (external).
IF you do it all assembled, is it just a pain to do the clear, say under the hood, etc?
I found one restoration guy that says paint it all assembled, as you get the body all set, and the bolts look nice afterwards. It eliminates the risk of reassemble scratches etc.
Opinions please....I can see the merit of painting it all together.
-bob (B5 70 cuda convert ready for paint next week).
67 hemi GTX silver 4spd, 70 cuda convert 340 4spd, 71 cuda 340 4spd (Curious Yellow, white billboards/interior), 70 Mr Norm's Challenger 440 4spd
Re: painting the factory way or not???? [Re: 5571] #1845886
06/10/15 05:33 PM
06/10/15 05:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sounds like an concourse wrongstoration so it really doesn't matter.
But if I were having it done wrong I would have it jammed , paint under the hood and the underside puke , assemble it then paint it.
Re: painting the factory way or not???? [Re: 5571] #1845938
06/10/15 06:26 PM
06/10/15 06:26 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Spraying it apart allows you flexibility with regards to 'access' that yer not gonna have if it's sprayed fully assembled...
Re: painting the factory way or not???? [Re: 5571] #1846041
06/10/15 08:05 PM
06/10/15 08:05 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
iagree and that's why a factory correct restoration will have bare metal and primer showing in those areas.
Re: painting the factory way or not???? [Re: 5571] #1846189
06/10/15 09:56 PM
06/10/15 09:56 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Make it better than new and you won't have rust in those hard to reach areas in a few years but this is a totally personal decision.
Sheldon
Sheldon
Re: painting the factory way or not???? [Re: 5571] #1846239
06/10/15 10:25 PM
06/10/15 10:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There is a 3rd option as well. Prime and seal everything while it's apart, even go as far as painting those areas with a "primer" textured and colored paint so it appears to be primer but is actually a nice sealed and painted surface. Then, assemble the car, gap everything so no further bolt adjusting is required, and blow the paint on factory style leaving areas dry and uncovered by body color as they should be. You might not get that look past an O.E. judge as being original, but not many others will pick up on it and it will appear basically "correct".
twocents
Re: painting the factory way or not???? [Re: ScottSmith_Harms] #1846500
06/11/15 11:03 AM
06/11/15 11:03 AM
mr norms avenue
5571 Offline OP
5571  Offline OP
mr norms avenue
thanks for all the responses. I like option 3.
By the way, is there a paint code somebody could recommend that matches the shade of the dipping primer?
Re: painting the factory way or not???? [Re: 5571] #1846524
06/11/15 11:47 AM
06/11/15 11:47 AM
MA
steve70 Offline
steve70  Offline
MA
1970 Challenger T/A 4 speed
Re: painting the factory way or not???? [Re: 5571] #1846548
06/11/15 12:35 PM
06/11/15 12:35 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Bare metal and primer is fine if the goal is to win at the Nats.....but for a car that gets driven, I wouldn't do it. Option 3 sounds good though or I'd just paint it full coverage.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
