Re: Pump Gas 540+ ci wedge builds...Let's hear em!!!
[Re: mshred]
#1845459
06/10/15 12:07 AM
06/10/15 12:07 AM
Posts: 289 Lowes
steve660
Lowes
The World wedge block I got has priority oiling and the 1st 4 mains are cross bolted...Be careful who you have build it.....some supposed Mopar Experts aren't so expert....I found out the hard way. Care to share who to avoid??? You can send me a pm if you like....Thanks for the info on the World Block My 22K purchase from MUSCLE MOTORS did not go as I had hoped....will probably have to part it out and start over. Your results may vary.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: steve660]
#1845465
06/10/15 12:15 AM
06/10/15 12:15 AM
Posts: 3,415 Toronto
mshred
Toronto
The World wedge block I got has priority oiling and the 1st 4 mains are cross bolted...Be careful who you have build it.....some supposed Mopar Experts aren't so expert....I found out the hard way. Care to share who to avoid??? You can send me a pm if you like....Thanks for the info on the World Block My 22K purchase from MUSCLE MOTORS did not go as I had hoped....will probably have to part it out and start over. Your results may vary. Ouchhhh...Well I would have avoided them anyways, dont hear much good about them unfortunately. Thanks for the heads up though, best of luck getting something together man!
[Re: mshred]
#1845516
06/10/15 01:33 AM
06/10/15 01:33 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Makes sense till you try hookin it up I guess but good luck either way. So then I was right, there are no 470-512" stock block stroker combos making 750-800hp on pump gas reliably? Guys out there making way more power then one of these like Im planning would make and hooking on even smaller tires...hooking does not worry me to be honest..thanks! Don`t know what my junk makes to run my et at 3200+ lbs but that was on 100 at the pump since we don`t have 93 out our way and trust me when I say if I knew then(3+ yrs ago)what I know 2day,that would of easily been a 9.59-9.63 run FWIW.............Guaranteed since it was straight off the trailer and first full 1/4 mile pass. Either way a 540 motor does sound like an e-ticket ride on the street or track.....
