SB remote oil filters #1845343
06/09/15 09:15 PM
06/09/15 09:15 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Does anyone have any photos of the block and fittings?
Re: SB remote oil filters [Re: justinp61] #1845363
06/09/15 09:32 PM
06/09/15 09:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is how I do it
wave
Re: SB remote oil filters [Re: MR_P_BODY] #1845386
06/09/15 09:54 PM
06/09/15 09:54 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Mikes pic is a good representation of how to do it. The lower hole around the outer diameter of the filter boss needs tapped to NPT and an appropriate sized NPT to AN fitting installed, that is your oil "out" of the block. Then through the filter ( the outer passage) and the oil goes "out" of the filter through the center passage and into the center passage of the block.
What size NPT do you tap your block to mike? I know the lines should at least be -10
Re: SB remote oil filters [Re: justinp61] #1845397
06/09/15 10:04 PM
06/09/15 10:04 PM
AndyF Offline
AndyF  Offline
There are a couple of ways to do it. The center bolt is easier but the oil has to take a few extra corners when you go that way.
Re: SB remote oil filters [Re: justinp61] #1845442
06/09/15 10:51 PM
06/09/15 10:51 PM
pennsylvania
poboyengineering Offline
pennsylvania
I have a kit to do this, and was just reading the MP engine book today. The lower pic seems to jive with what they were saying, but mine came with the parts to do the upper one(center hole).
Just wondering what the difference would be...
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: SB remote oil filters [Re: justinp61] #1845483
06/09/15 11:36 PM
06/09/15 11:36 PM
W. Kentucky
W. Kentucky
Thanks guys, mine will be like the second photo Andy posted.
There's water in that hole.
Re: SB remote oil filters [Re: justinp61] #1845543
06/10/15 01:43 AM
06/10/15 01:43 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I make things like this, it's very common down here
Alan Jones
Re: SB remote oil filters [Re: LA360] #1845547
06/10/15 01:48 AM
06/10/15 01:48 AM
LA360 Offline
LA360  Offline
On the engine
A kit I have to start producing again
Alan Jones
Re: SB remote oil filters [Re: justinp61] #1845571
06/10/15 05:09 AM
06/10/15 05:09 AM
Australia Qld
V
VG423 Offline
VG423  Offline
V
Australia Qld
Drill and tap for 3/8 NPT,straight in and out less 90 degree turns.
Re: SB remote oil filters [Re: VG423] #1845656
06/10/15 11:01 AM
06/10/15 11:01 AM
Here
jcc Online content
No soup for you!!!
jcc  Online Content
No soup for you!!!
Here
I believe Andy commented years back about the difficulty of tapping this location for 1/2" NPT, 3/8" being the norm and shown in this thread. Anybody do 1/2", and how did it go?
And, is there any safe way/trick to tap this location, WITHOUT tearing the motor down, to insure no metal shaving go astray?
I forbid my content here from being learned and used by artificial intelligence systems.
Re: SB remote oil filters [Re: jcc] #1845662
06/10/15 11:13 AM
06/10/15 11:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I did one with a hand drill.. it turned out ok but
it had a small seep all the time... all the rest that
I have done are on the mill... you better decide to do
it prior to the build up... are there ways to do it..
yes but I sure wouldnt want to chance it
EDIT
You would be farther ahead if you bought one of those
plates and used that.. if its already built.. and if
its in the car thats about the only way
wave
Re: SB remote oil filters [Re: LA360] #1845816
06/10/15 02:54 PM
06/10/15 02:54 PM
K
Kiddart Offline
Kiddart  Offline
K
LA360 do you sell that Kit? if not where do I go to get one?
Thank you
Kiddart
Re: SB remote oil filters [Re: Kiddart] #1845834
06/10/15 03:13 PM
06/10/15 03:13 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I would like one of those kits, too. Actually it looks pretty easy to make. And the idea of a remote filter makes it easy to change
I had a major blowout while I was under my 360 powered truck and the gasket gave up under the filter mounting plate eek
And a racer here had one let go in the lights at speed eek eek
the car spun off to the left, luckily it stayed upright and did not hit anything solid. It still cost him a set of wheels and tires (bent and flat spotted). Could have been a lot worse.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: SB remote oil filters [Re: justinp61] #1845967
06/10/15 05:43 PM
06/10/15 05:43 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
Wher do you get the centerbolt for #2 pic?
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: SB remote oil filters [Re: fed] #1845996
06/10/15 06:07 PM
06/10/15 06:07 PM
W. Kentucky
W. Kentucky
The center bolt is just a fine thread 3/4" bolt, 3/4 X 16tpi.
Re: SB remote oil filters [Re: Kiddart] #1846076
06/10/15 07:55 PM
06/10/15 07:55 PM
LA360 Offline
LA360  Offline
I do, but I am going through a divorce, so I stopped making them for a while and have no stock. I am just starting to produce stuff again now. Feel free to PM me for more details
Alan Jones
Re: SB remote oil filters [Re: fed] #1846113
06/10/15 08:15 PM
06/10/15 08:15 PM
AndyF Offline
AndyF  Offline
Damper bolt will work if you make it a little shorter.
Re: SB remote oil filters [Re: justinp61] #1846227
06/10/15 09:14 PM
06/10/15 09:14 PM
W. Kentucky
W. Kentucky
I picked up a 2" fine thread bolt at Fastenal today, it was the shortest they had in stock. About 3/4" would be ideal. I'm also going to use a 3/4" copper crush washer under it.
Re: SB remote oil filters [Re: jcc] #1846305
06/10/15 10:48 PM
06/10/15 10:48 PM
AndyF Offline
AndyF  Offline
It is easy to drill and tap that hole if you have the proper fixture and an extra tall Bridgeport.
Re: SB remote oil filters [Re: justinp61] #1846316
06/10/15 10:56 PM
06/10/15 10:56 PM
W. Kentucky
W. Kentucky
I don't have a mill so I just drilled mine with a cordless drill, will pick up the tap tomorrow.
