Re: 727 issues
[Re: PC-CHARGER]
#1845354
06/09/15 10:24 PM
06/09/15 10:24 PM
RapidRobert
if the cooler lines have psi I would think the pump is pumping. I would wait for Kunkel to come to & chime in (he's the man) but for now I would pull the pan & at least take a peek at the VB linkage
Re: 727 issues
[Re: PC-CHARGER]
#1845505
06/10/15 01:13 AM
06/10/15 01:13 AM
RapidRobert
If the pump lugs have broken, there may still be enough drag to pump oil out the cooler lines but not enough to operate any clutches. Oh OK
Re: 727 issues
[Re: PC-CHARGER]
#1845780
06/10/15 03:07 PM
06/10/15 03:07 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the pump lugs have broken, there may still be enough drag to pump oil out the cooler lines but not enough to operate any clutches. That's my thinking too.
Re: 727 issues
[Re: bigbertha72]
#1845864
06/10/15 05:02 PM
06/10/15 05:02 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I've seen 904's sheer the lugs in a non race application , but not a 727 , not that it couldn't happen.
Did you check the fluid level ? Try reverse ?
