New electrical issue - Brights and gauges? #184521
01/05/09 01:58 PM
01/05/09 01:58 PM
Farmland, IN
Ludington1 Offline OP
Farmland, IN
Took my car out for a short trip last night and on a dark stretch of road I hit the brights. Noticed a few seconds later that the temp, oil pressure, etc. small gauges were all "dead" and the needles over to the far left. Kicked off the brights and the gauges came back to life. Tried it again and the same thing happened to the gauges.
It has been quite a while since I've used the brights, so I can't tie it into anything specific that I've worked on lately, but I haven't done anything electrical in a while to the car.
Any ideas where this issue might be coming from?
Thanks,
Darren
Re: New electrical issue - Brights and gauges? [Re: Ludington1] #184522
01/05/09 02:07 PM
01/05/09 02:07 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
One guess would be a bad common ground to the gauges. I don't mean that like the "check the grounds" catch-all response you sometimes get on problems like this.
What does the high beam indicator do when you hit the brights? If it doesn't come on, or does so dimly, that is an indication that the indicator bulb and high beam circuit might be providing the gauge ground, and goes away when power is applied from the other side. An easy way to see if I'm all wet is to pull the high beam indicator bulb and see if that kills your gauges.
Oh yeah. And check the grounds.
Down to just a blue car now.
Re: New electrical issue - Brights and gauges? [Re: Ludington1] #184523
01/05/09 10:14 PM
01/05/09 10:14 PM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
Do you have halogen headlight bulbs?
Re: New electrical issue - Brights and gauges? [Re: dragaddict] #184524
01/05/09 10:16 PM
01/05/09 10:16 PM
Farmland, IN
Farmland, IN
Thanks guys... actually yes they're halogens... does that make a difference?
Darren
Re: New electrical issue - Brights and gauges? [Re: 68HemiB] #184525
01/05/09 10:19 PM
01/05/09 10:19 PM
Farmland, IN
Farmland, IN
High-beam indicator does come on, can't say if it is dim or not. I can try to pull the bulb tomorrow and see if that makes a difference. I thought the cluster ground was via the screws into the dash frame?
Thanks again!
Darren
Re: New electrical issue - Brights and gauges? [Re: Ludington1] #184526
01/05/09 10:31 PM
01/05/09 10:31 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I believe your dash uses a regulator to control your gauges. It is a switching regulator that converts 12V battery to 5 Volt reference voltage for all of your gauges. They are notorious for failing but usually not in this manner. They were used on a wide range of Chrysler vehicles and very easy to find. RT-Engineering makes a modern version that is much more reliable and has protection to keep your gauges from burning up.
I would recommend you check this right away: if there is an over voltage situation it WILL fry your gauges.
Craig
Re: New electrical issue - Brights and gauges? [Re: denfireguy] #184527
01/05/09 10:39 PM
01/05/09 10:39 PM
Farmland, IN
Farmland, IN
Craig
Thanks Craig, installed the solid-state limiter from RT-Eng several months ago.
Darren
Re: New electrical issue - Brights and gauges? [Re: Ludington1] #184528
01/05/09 11:22 PM
01/05/09 11:22 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Good, scratch that then!
Re: New electrical issue - Brights and gauges? [Re: Ludington1] #184529
01/06/09 01:11 AM
01/06/09 01:11 AM
N
NITROUSN Offline
NITROUSN  Offline
N
It is. Lots of things can happen when you loose the ground. Two main points. The printed circuit board needs to grounded to the main housing VIA the screws that hold the printed board to the cluster. Most likely only one controls the ground so make sure all are tight. Second is the screws that hold the cluster to the dash frame. It cant be loose from there. Best way is to install a ground wire from the cluster housing to a good body ground and then make sure all the screws that hold the printed circuit board in are tight,
When you hit the brights the indicator must of stole the printed circuits board ground.
Head lights are a different circuit and have zero bearing on your problem.
Re: New electrical issue - Brights and gauges? [Re: Ludington1] #184530
01/06/09 02:49 AM
01/06/09 02:49 AM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
If you are going to run halogen lights you need to feed them thru a relay with the light switch and dimmer being the signal and not the power source. I have a 69 Coronet and this works.
Re: New electrical issue - Brights and gauges? [Re: dragaddict] #184531
01/06/09 10:24 AM
01/06/09 10:24 AM
Farmland, IN
Farmland, IN
Headlights have been on relays for quite a while, I'm going to see if I can add an additional ground to the cluster today.
Thanks again for everyone's help.
Darren
Re: New electrical issue - Brights and gauges? [Re: Ludington1] #184532
01/06/09 11:04 AM
01/06/09 11:04 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
i was having a problem with my lights going out and it ended up being the head lite switch.
Re: New electrical issue - Brights and gauges? [Re: 3ddart] #184533
01/06/09 12:11 PM
01/06/09 12:11 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
HONESTLY I would think more on poor positive contact around. we can talk about bulkhead, ammeter stud, Battery terminal, alternator stud, starter relay stud.
another positive point to check is on back of fuse box... buss bars. Terminals get sulfated/corroed. ACTUALLY I'm working on a Dart fusebox with that problem, where quite often loose the cluster lights, wrong gauge readings, and even non working back up lamps! We discover is on fusebox. FUSE TERMINALS WERE GETTING INCREDIBLE HOT and then cluster lights died. Fuses never blow. We are using battery ends cleaner since that is used to remove sulfated surfaces
clusters normally does have LOOOOOOTS of ground locations with each screw what makes me hard to think a ground problem. I never have found a ground problem on a cluster... maybe yes on block, ground body strip or something like that
AND REMEMBER it couldn't be a ground on cluster if we are talking about gauges BECAUSE GUAGES ARE DRIVEN BY VARIABLE NEGATIVE coming from senders, so gauges are isolated on cluster
Re: New electrical issue - Brights and gauges? [Re: NachoRT74] #184534
01/06/09 12:32 PM
01/06/09 12:32 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Read his first post. When the high beam indicator comes on the guages quit. To me thats a sign of a ground path being removed. I have the fsm in front of me and I will bet if there is a ground applied to the proper grounding screw for the circuit board that will fix the problem.
Re: New electrical issue - Brights and gauges? [Re: Ludington1] #184535
01/06/09 02:51 PM
01/06/09 02:51 PM
Shoreline, Washington
72roadrunnergtx Offline
The voltage limiter is not completely grounded and is likely operating from a ground path provided though the high beam indicator bulb and high beam relay. Energizing this circuit removes this ground path. Not sure what dash you have, I assume it is based on a printed circuit board. If that’s the case I believe the voltage limiter is “plugged” into your circuit board. The FSM diagram I’m looking at shows a trace running from the voltage limiter to the high beam indicator blub with another trace providing the ground for both running from a PCB mounting screw. A fault with this trace will create your symptoms. If the entire cluster had a ground fault you would have other indicator/illumination lights inop.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: New electrical issue - Brights and gauges? [Re: 72roadrunnergtx] #184536
01/06/09 03:07 PM
01/06/09 03:07 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Your looking at an entirely different diagram.
Re: New electrical issue - Brights and gauges? [Re: NITROUSN] #184537
01/06/09 03:33 PM
01/06/09 03:33 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yeah forgot printed circuit boards use a "plugg in" limiter and of course need ground on board. However I don't think is CLUSTER ground like IF is a ground problem is JUST the VOLTAGE LIMITER GROUND TERMINAL! not really cluster. Cluster ground problem should dimm gauge lightning too when fail is present.
that's at least what logic comes to mind.
Re: New electrical issue - Brights and gauges? [Re: NachoRT74] #184538
01/06/09 04:08 PM
01/06/09 04:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Here is the logic on that side of the dash. There are two grounds on the board. They both ground with screws. One ground is just for one dash light bulb located far right. The second grounds one other dash light and the limiter. Its possible that this bulb is bad. either way i do believe the ground is being removed from this board. I do have a cluster in the shop that makes it more understandable. All the rest of the bulbs ground to the cluster[all metal] In other various points. No more circuit boards in those areas. If it were me I would install an extra ground wire from a good body area to the upper left[facing the dash]or[ the upper right screw if looking from behind] screw that holds the circuit board to the cluster. This will ground the cluster and circuit board. I will just about bet if all the cluster to dash frame bolts are tightened along with the circuit board to cluster screws the problem will go away.
Re: New electrical issue - Brights and gauges? [Re: NachoRT74] #184539
01/06/09 06:00 PM
01/06/09 06:00 PM
Farmland, IN
Farmland, IN
Thanks again, I didn't get a chance to mess with it today, but I think the cluster ground must be the issue. I went out and turned off the garage lights and turned on the headlights, cluster lights DO dim when I hit the brights. It is the plug-in type solid-state limiter, as stated above.
I'll have to look and see if I can get to the screw mentioned above and see if I can get a terminal on it without pulling the cluster and run it to the body somewhere. Tomorrow... maybe...
Darren
Re: New electrical issue - Brights and gauges? [Re: NITROUSN] #184540
01/06/09 06:07 PM
01/06/09 06:07 PM
Farmland, IN
Farmland, IN
If it were me I would install an extra ground wire from a good body area to the upper left [facing the dash] or [the upper right screw if looking from behind] screw that holds the circuit board to the cluster. This will ground the cluster and circuit board. I will just about bet if all the cluster to dash frame bolts are tightened along with the circuit board to cluster screws the problem will go away.
Looking at your spare cluster, where is the screw in relation to the headlight switch connection on the back of the cluster? I'll have to get out my FSM and take a look.
Darren
