71 charger #1845176
06/09/15 07:38 PM
06/09/15 07:38 PM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
I just started driving my 71 RT..I noticed at idle or in drive my alternator gauge is a little past charging properly .. when driving the needle is almost pinned is this normal or am I overcharging? I changed the voltage regulator and does the same thing..
Re: 71 charger [Re: FC7 cuda] #1845824
06/10/15 04:05 PM
06/10/15 04:05 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Normally I've only ever seen that when using the alternator to recharge a dead or low battery.
Re: 71 charger [Re: DaytonaTurbo] #1845837
06/10/15 04:18 PM
06/10/15 04:18 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
See if your battery is fully charged or not. Then take for a drive. After battery fully charged if problem is still there could be in Regulator (which you tried already) alternator or wiring.
Ron
