Re: 383 head gaskets.............
[Re: InViolent]
#184484
01/05/09 02:15 PM
01/05/09 02:15 PM
Posts: 4,978 VA
DAMOPARS
VA
I would go with Fel-Pro head gaskets and skip the steel shims. You'll get a better seal, and you'll only see a 3 or 4% difference in compression ratio. Mancini Racing sells the steel shim gaskets if you are so inclined. Or check Summit or Jegs.
If you do use steel gaskets get the copper spray sealer and do both side of the gasket.
[Re: BRawls]
#184487
01/05/09 10:05 PM
01/05/09 10:05 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I ran the steel head gaskets some years back on a mild 383. I used the Permatex red spray sealer and it worked great. The eng was in my boys Dart for 7 years with no leaks or problems until he decided he needed to go faster and we built the current 400 in it. Ron
[Re: 383man]
#184488
01/06/09 12:56 AM
01/06/09 12:56 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
You need every trick you can get to keep compression up in a 383. I have steel shim gaskets in mine right now, been a couple years, no problems whatsoever, and their worth darn near half a point in compression. I spray mine with copper-coat. IMO, if you're running a stock piston 383, they are required material!
[Re: 4BBodies]
#184489
01/06/09 01:25 AM
01/06/09 01:25 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
..........it has been recommended that I purchase a pair of Mopar steel shim head gaskets to help compression with my stock 383 slugs. Does anyone have a part# for these? Also, what type of gasket sealer should I use? Thanks all!
You're too late!!!
Mopar just went and obsoleted those $20.00 steel gaskets and now they offer a $200.00 set in their place!!
That sucks 'cause I used a lot of those gaskets myself and am gonna miss them.
[Re: 4BBodies]
#184490
01/06/09 01:26 AM
01/06/09 01:26 AM
RapidRobert
using steel shim ones I'd make sure your block/head are perfectly flat
[Re: InViolent]
#184494
01/06/09 09:32 AM
01/06/09 09:32 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Evidently Chrysler didn't have a sealing problen,thats all they ever used on a B engine!
[Re: Junky]
#184496
01/06/09 11:51 AM
01/06/09 11:51 AM
Posts: 4,389 Kenmore, New York
InViolent
Kenmore, New York
Yes, on a freshly machined block and heads. Did the poster say this was a fresh rebuild? I assumed when he said "stock flat-tops" that this was a clean-up job and not a new-build performance motor.
I would like to see proof that you can pick up 1/2 point of compression between .039 and .020 head gasket on a 383.
In a typical case...you might be looking at a difference of 7.9 Static C/R and 8.2 Static C/R on a bone stock 383. Do you really think this makes any difference at all in a simple stock build motor? My experience has been that if you are not building for maximum performance, go the safe route and avoid unecessary problems. Did you ever see the article in one of the Mopar rags where they added head gaskets on top of head gaskets in a 440 to reduce C/R and determine what the HP difference was? it was like 20HP per point. It is simply not worth the trouble to try to squeeze a few ponies out a stock 383 in my opinion.
[Re: RapidRobert]
#184500
01/09/09 03:31 AM
01/09/09 03:31 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I believe cometic makes an mls gasket that is only .027 thick.
A guy on here once stated that he was only able to get his MLS head gaskets to seal by coating each of the 3 layers with permatex spray sealer, the red stuff.
I've heard that too. I've also heard that a special finish is required for these gaskets.
In real life I've installed a bunch of them, with nothing more than a spray of copper coat.(and even 3 sets dry) With no special finish or machining. No issues yet.
I would not hesitate to use them on anything
The only reason I don't use them on everything is cost, and that they simply aren't needed on most things.
To me they are simply unbeatable if you need a special thickness, be it over size to reduce comp, or something really specific to get quench etc..
