U joint strap bolts - L'il Help
#1844520
06/08/15 09:42 PM
06/08/15 09:42 PM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Aren't all yokes supposed to use the same bolts?
I bought a universal strap kit for the 8 1/4 rear end and the damn bolts don't fit. They run in 1/8 inch and lock up, the threads come out starting to be smashed.
Does anyone know the actual bolt dimension that is supposed to be used?
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: U joint strap bolts - L'il Help
[Re: 70Coronet500Vert]
#1844574
06/08/15 10:38 PM
06/08/15 10:38 PM
RapidRobert
They run in 1/8 inch and lock up, the threads come out starting to be smashed. What Buildanother said, the wrong pitch (coarse vs fine)
#1844796
06/09/15 08:54 AM
06/09/15 08:54 AM
70Coronet500Vert
St Charles MO
I think they were heavily corroded. I kept getting lots of rust out. Finally, I oiled them up, cut them to 1/4 x 20 and made sure to use thread lock. 20 ft lbs of torque is not much, so I think it was OK to cut them.
I could not find the 1/4 x 28 tap at any store.
#1844986
06/09/15 03:20 PM
06/09/15 03:20 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
I could not find the 1/4 x 28 tap at any store. Hopefully the bolts stay put, changing thread pitch by retapping a hole that was already tapped isn't something that is recommended.
#1845277
06/09/15 09:24 PM
06/09/15 09:24 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I would have tried harder for that fine thread tap but the straps do not do much. All of the engine's torque is contained by the yoke. The straps do nothing more than keep the drivershaft from sliding forward into the spline and falling out of the yoke.
