converter balance? #1844530
06/08/15 09:50 PM
06/08/15 09:50 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Are converters for a 400 with a cast crank balanced the same as a 440 with a cast crank?
Re: converter balance? [Re: mopfried] #1844795
06/09/15 08:44 AM
06/09/15 08:44 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Well I guess all BB with cast cranks are balanced the same, or use a neutral balance converter with a B&M flex plate.
Re: converter balance? [Re: mopfried] #1844902
06/09/15 12:54 PM
06/09/15 12:54 PM
dogdays Offline
dogdays  Offline
Short answer: yes.
Even the harmonic dampers are the same, though they are marked for 400 cast crank only or for 440 cast crank only, maybe even for 383 cast crank only.
R.
Re: converter balance? [Re: mopfried] #1845111
06/09/15 06:02 PM
06/09/15 06:02 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I have two, one from a 440 and one from a 400. I am having one rebuild... long story, anyhow the 400 converter is smaller in diameter.
