Which oil pan is this , big block #1843807
06/07/15 10:58 PM
06/07/15 10:58 PM
Sydney,Australia
tex013 Online content OP
tex013  Online Content OP
Sydney,Australia
Which pan and what does it fit ?
Was on my 440 when i got it . Would need baffles for performance use . Pickup i have with it is 3/8 - 1/2 off the floor if pan
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Which oil pan is this , big block [Re: tex013] #1843902
06/08/15 12:43 AM
06/08/15 12:43 AM
Cab_Burge Online work
Cab_Burge  Online Work
C body, probally around 1962 to 1971 shruggy There where several different pans that look like that , some had numbers stamped into them and some didn't confused
Re: Which oil pan is this , big block [Re: tex013] #1843907
06/08/15 12:51 AM
06/08/15 12:51 AM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
1968 & 1969 (maybe others) B body hemis had a similar setup as well with the space for the idler arm set into the pan. But the hemi setup would have the baffles, so yes, probably out of a C body.
Re: Which oil pan is this , big block [Re: tex013] #1843910
06/08/15 12:55 AM
06/08/15 12:55 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Also for big block into A body... I've had a few around. (Have a similar no number one still now.)
As mentioned, with the idler arm notch...
Re: Which oil pan is this , big block [Re: tex013] #1843942
06/08/15 02:02 AM
06/08/15 02:02 AM
Sydney,Australia
Sydney,Australia
Thanks guys
Tex
New best MPH 130.32
