Isopropyl mechanical temp gauge instructions #1843509
06/07/15 04:51 PM
06/07/15 04:51 PM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
Hello, miss placed my install instructions for mechanical water temp gauge, two taps on back just for back light? Mechanical part all hooked up, wiring part I'm questioning help please?
Re: Isopropyl mechanical temp gauge instructions [Re: meepmeep70] #1843548
06/07/15 05:36 PM
06/07/15 05:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I thought all water temp gauges were electric?, never seen a mechanical one.
Re: Isopropyl mechanical temp gauge instructions [Re: Challenger 1] #1843637
06/07/15 08:18 PM
06/07/15 08:18 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Can't help with the wiring for the light. There should just be a single wire coming out of the light socket.I'm not sure what these 2 taps are you see.
For Challenger 1, mechanical oil temp gauge poached from Google Images.
Kevin
Re: Isopropyl mechanical temp gauge instructions [Re: Challenger 1] #1843796
06/07/15 10:53 PM
06/07/15 10:53 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Don't know what taps the op is talking about. Probably the studs the bridge goes on to hold the gauge in the dash. One wire is ground, the other wire goes to the park lights.
Re: Isopropyl mechanical temp gauge instructions [Re: Twostick] #1843800
06/07/15 10:55 PM
06/07/15 10:55 PM
Cincinnati, Ohio
Cincinnati, Ohio
Kevin
Show me a mechanical water temp gauge, can't imagine where's there room for a big probe like pictured.
Re: Isopropyl mechanical temp gauge instructions [Re: Challenger 1] #1843812
06/07/15 11:00 PM
06/07/15 11:00 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Autometer has them. I have one in my water pump hsg, sb.
Re: Isopropyl mechanical temp gauge instructions [Re: meepmeep70] #1843846
06/07/15 11:37 PM
06/07/15 11:37 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
http://www.autometer.com/media/2650-1606.pdf
Tabs/terminals will only be on the internal LED models. If you are talking about the two threaded studs, those are for the hold-down bracket. Don't put any wires on them.
Re: Isopropyl mechanical temp gauge instructions [Re: Challenger 1] #1843889
06/08/15 12:29 AM
06/08/15 12:29 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
Kevin
Re: Isopropyl mechanical temp gauge instructions [Re: meepmeep70] #1843975
06/08/15 02:53 AM
06/08/15 02:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If you look just to the right of my thermostat housing (pass side) you can just see where my mecanical water temp gauge goes into the pump housing. Thats part of a wire harness in front of the temp gauge port between it and the rad shroud. Ron
Re: Isopropyl mechanical temp gauge instructions [Re: Twostick] #1844056
06/08/15 10:04 AM
06/08/15 10:04 AM
weymouth,mass.
weymouth,mass.
Kevin
Kevin
That is the gauge I have, look at back side, two male terminals, yes the sensor fits into the water pump housing. maybe one is ground and the other switched 12v?
Re: Isopropyl mechanical temp gauge instructions [Re: meepmeep70] #1844088
06/08/15 11:35 AM
06/08/15 11:35 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
The black and white wires are for the bulb or LED illumination for night use. Gauges are hard to see at night without being illuminated. up
Re: Isopropyl mechanical temp gauge instructions [Re: meepmeep70] #1844092
06/08/15 11:43 AM
06/08/15 11:43 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Autometer make two models. One has a standard bulb that pops out of the housing. It has a black and white wire. The other is an internal LED lighted unit.
Re: Isopropyl mechanical temp gauge instructions [Re: meepmeep70] #1844129
06/08/15 12:55 PM
06/08/15 12:55 PM
weymouth,mass.
weymouth,mass.
Thank you.
