2-650's vs. 2-750's on tunnel ram #1843763
06/07/15 10:23 PM
06/07/15 10:23 PM
Saskatchewan (SK)
79410aspenrt Offline OP
Saskatchewan (SK)
i'm swapping out 2-650's for 2-750's on my 440'' small block.
do you guys think this is a good swap or not?
Re: 2-650's vs. 2-750's on tunnel ram [Re: 79410aspenrt] #1843882
06/08/15 12:23 AM
06/08/15 12:23 AM
Only time will tell work How well tuned are the current carbs.? How big is your small block and what is the intended use of the motor now? If it is the car and motor on your signature I would do it to find out up twocents In fact I would be looking for bigger carbs (850,1050) than those two sizes you are dealing with now up smile I like HP and torquepower, more air and fuel normally make Mopower up
Re: 2-650's vs. 2-750's on tunnel ram [Re: 79410aspenrt] #1843915
06/08/15 01:03 AM
06/08/15 01:03 AM
Saskatchewan (SK)
Saskatchewan (SK)
440 cubic inch small block that's race only. the 650's are tuned well.
Re: 2-650's vs. 2-750's on tunnel ram [Re: 79410aspenrt] #1844149
06/08/15 01:31 PM
06/08/15 01:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are the 650s vac secondaries.. and the 750s a mech
secondary .. you should like the new carbs
wave
Re: 2-650's vs. 2-750's on tunnel ram [Re: MR_P_BODY] #1844178
06/08/15 01:54 PM
06/08/15 01:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed and I wouldn`t put a vs on ANYTHING and remove em when I can w/excellent results....... thumbs
Re: 2-650's vs. 2-750's on tunnel ram [Re: 79410aspenrt] #1844220
06/08/15 02:27 PM
06/08/15 02:27 PM
gregsdart Offline
gregsdart  Offline
It probably depends on how good your heads are. With 440 cubes, I am betting you have some great heads, and can use the bigger carbs, maybe bigger yet depending on airflow and rpm.
Re: 2-650's vs. 2-750's on tunnel ram [Re: 79410aspenrt] #1844746
06/09/15 01:39 AM
06/09/15 01:39 AM
Saskatchewan (SK)
Saskatchewan (SK)
the 650's are DP's.
Re: 2-650's vs. 2-750's on tunnel ram [Re: 79410aspenrt] #1844949
06/09/15 02:23 PM
06/09/15 02:23 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
My 383 loved the 750's on it, bigger motor, bigger carbs!
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
