68 R/R with decore Radio speaker Qs. #1843009
06/06/15 06:43 PM
06/06/15 06:43 PM
W
Wagonman1967 Offline OP
W
So I have the dash out and apart. The center speaker is there and hooked to a harness with some kind of box and two leads that look like they go to speakers in the corners of dash. The dash is cut out for about a 3in speaker on both sides.Was this factory? The holes are kinda rough looking but with the Mopar harness I have to think it is. Was there an option for this. I dont see any wiring in the rear harness but the package tray is cut for 2. I assume all trays had the cut outs.
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: 68 R/R with decore Radio speaker Qs. [Re: Wagonman1967] #1843120
06/06/15 10:20 PM
06/06/15 10:20 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Sounds like the optional AM/tape option, which included a speaker at each dash corner; pretty rare.
Yes, 2 speaker locations were punched in the rear package trays, some were oriented same direction, some not; a production-date thing, IIRC.
Re: 68 R/R with decore Radio speaker Qs. [Re: topside] #1843160
06/06/15 11:41 PM
06/06/15 11:41 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
Rear speaker was optional,and only one,
other speaker hole is for rear window defrost option!
Re: 68 R/R with decore Radio speaker Qs. [Re: Wagonman1967] #1843163
06/06/15 11:43 PM
06/06/15 11:43 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, the AM/8-track would have 3 dash speakers but most I've seen have nicely cut holes in the dash. What's on the fender tag under the upper case "P" & "R"? Sounds like a possible dealer installation? shruggy
Re: 68 R/R with decore Radio speaker Qs. [Re: Wagonman1967] #1843466
06/07/15 03:22 PM
06/07/15 03:22 PM
W
W
Thanks Dan. Fender tag shows nothing under the P and a Zero under the R. If it was a dealer option they would have to pull the windshield,Correct?? Seems a little unlikely. There is a tag on the harness says Chrysler 2889-534 and below that 95329. I have looked for Pics of the speakers but have found none showing the outer speakers. Finding speakers is not going to be a chore but the correct grills is going to be something else.
2001 Dodge Ram 4wd
