Page 1 of 3 1 2 3
Need some Indy cylinder head rocker arm help #1842810
06/06/15 12:13 PM
06/06/15 12:13 PM
MT PLEASANT, IA
BARRACUDA340S Offline OP
MT PLEASANT, IA
I bought the 360-2 heads for my 416 about 10 years ago. I might have 1500 miles on the motor now. The car has pretty much sat since 2007. I get it out a few times a year. Anyway I fired it up yesterday and the valve train was unusually noisy. Solid lift cam but something was off so I shut it down and pulled the valve covers. Oil everywhere which was good but I grabbed an intake rocker and it was real loose on lash. I just set the valves maybe 200 miles ago. Looked at push rods and could see they had a bunch of heat in them so I pulled the rocker shafts. Sure enough I had 3 rockers that mushroomed the push rod cup and beat up the adjust ball. Looks like lack of oil creating heat.
Shafts are fine, cleaned them up on the lathe with emery cloth but prior to that a couple rockers were starting to get tight.
I don't think I have an oiling issue here as far as the oil pump, pressure etc. I'm wondering if I'm letting the car sit too long between firing it up and I'm dry starting the motor. Or do I have a rocker arm issue?
A friend of mine who's and engine builder, mostly GM stuff looked at the rockers and asked me why there's no bearing (aluminum rocker to metal shaft) and also why the oiling holes in the rockers don't have a channel from the center of the rocker to the oiling hole?
I also have one intake rocker that wasn't machined all the way on the oiling channel.
Bad rocker
All the rest where done right
exhaust rocker arms, no groove for oil.
Push rods
Where do I go from here? I've been out of the Mopar scene now for 8 years doing other projects.
I know I need new push rods and rocker adjusters.
Where can I get the rocker adjusters? I believe these rocker arms are Indy's. Do I need to modify them for better oiling or move on to a better rocker?
I need to get the car running by Friday. I'm committed to an event and the car needs to be there.
Any help here would be appreciated.
Thanks Brett
Re: Need some Indy cylinder head rocker arm help [Re: BARRACUDA340S] #1842839
06/06/15 01:02 PM
06/06/15 01:02 PM
AndyF Offline
AndyF  Offline
Firing up the engine with it dry like that wasn't a good idea. If it had been sitting a long time then there wasn't much lubrication left in the rocker assembly and things probably galled up. It is a hassle to pull the distributor and pre-oil the engine, but it is less work that replacing a bunch of parts.
Looks to me like you need a new set of pushrods at the very minimum. You might also need to replace some rocker arms or buy a new set. I can't really tell you what is going on with those rocker arms without looking them over in person. There should be a way for the oil to get everywhere it needs to go so that is what you need to look at. The shafts might have grooves on them for example. You should be able to put the whole assembly together and then spin the oil pump with a speed wrench and see oil dripping out of each rocker arm.
Re: Need some Indy cylinder head rocker arm help [Re: AndyF] #1842843
06/06/15 01:15 PM
06/06/15 01:15 PM
MT PLEASANT, IA
MT PLEASANT, IA
I have a priming tool and yes I should have either primed it after letting it sit for long periods of time or start it on a regular basis.
I have a call in to Ryan at Shady Dell. He did the heads for me 10 years ago. I can't comment on the quality of these rockers other than the one rocker that wasn't fully machined. They don't appear to be that great of quality to me.
I did some searching and T&D makes a rocker for the 360 Indy heads but can't find any pictures. I'd like to see how they're machined for oiling and if they're a better set up for the street. I don't race the car anymore just some street duty now. My long term plan is to put this motor in another A body down the road and go back to the track and then build a nice street friendly 340 for the Cuda. I just need to make the best of what I have for the time being without hurting the valve train if I want to go for a cruise.
Re: Need some Indy cylinder head rocker arm help [Re: BARRACUDA340S] #1842889
06/06/15 02:34 PM
06/06/15 02:34 PM
AndyF Offline
AndyF  Offline
Ryan is a good guy to talk to, he'll know what rocker arms to run on that engine. T&D is generally one of the very best rocker arms. I don't have any experience with their SB rocker arms but their BB stuff is premium grade.
You can also check out what Hughes Engines offers for those heads. The guys at Hughes have spent a bunch of time working out the various bugs in the Mopar rocker arm design. I'd trust their stuff over anyone else in the mid-price range.
Re: Need some Indy cylinder head rocker arm help [Re: BARRACUDA340S] #1842895
06/06/15 02:52 PM
06/06/15 02:52 PM
USA
B3RE Offline
B3RE  Offline
USA
If this is what you want, you really need to give me a call or PM me.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Need some Indy cylinder head rocker arm help [Re: BARRACUDA340S] #1842903
06/06/15 03:16 PM
06/06/15 03:16 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a complete set Indy rockers and pushrods off a 360-1 motor I bought. PM me if you're interested, I'm going with a solid roller and will use T&Ds.
Re: Need some Indy cylinder head rocker arm help [Re: justinp61] #1842908
06/06/15 03:38 PM
06/06/15 03:38 PM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
I bought 4 rockers directly from Indy last year. I had no issues with them, despite all the bad stories you read on forums. I have 360-2 heads also. IMO Id go with justinp61"s offer...
I also would think it was due to dry start up.
Goodluck.
Re: Need some Indy cylinder head rocker arm help [Re: BARRACUDA340S] #1842928
06/06/15 04:27 PM
06/06/15 04:27 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
I would go with a set of t&d if you can. If not see what Hughes has to offer as Andy suggested. I have been using the t&d for the last 8 years spraybar oiling with no issues of yet. Haven't heard anything from you since mopartech died. Good to see you still have you barracuda.
Re: Need some Indy cylinder head rocker arm help [Re: BARRACUDA340S] #1842970
06/06/15 05:46 PM
06/06/15 05:46 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
get those junk indy rockers off of there and get hardland sharps,you will need new push rods,smith bros push rods would make you some up quick
Re: Need some Indy cylinder head rocker arm help [Re: BARRACUDA340S] #1842991
06/06/15 06:25 PM
06/06/15 06:25 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
I think you've got some more serious issues. Those pushrods didn't get that color with just a few seconds of cold starts. They got hot, real hot from no oil. If you know what valves the worst ones came from, look at the rockers and ball adjusters for the same valves. Was all the damage from the same side of the motor? The pushrods also appear to have a lot more scuffing than I am used to seeing.
Re: Need some Indy cylinder head rocker arm help [Re: justinp61] #1843375
06/07/15 12:59 PM
06/07/15 12:59 PM
MT PLEASANT, IA
MT PLEASANT, IA
What length are the push rods?
Re: Need some Indy cylinder head rocker arm help [Re: shorthorse] #1843381
06/07/15 01:10 PM
06/07/15 01:10 PM
MT PLEASANT, IA
MT PLEASANT, IA
I had damage on 3 rockers where the ball adjuster and pushrod cup were going away. The rest were ok but it would have just been a matter of time. 2 on the drivers side and 1 on the passenger side. 2 intake rockers and 1 exhaust.
I'm ordering new ball adjusters today from summit and will have to hustle for push rods tomorrow. I need to get through the show this weekend and regroup. I have plenty of oil up to the heads but as to why the it's not oiling the rockers properly is a mystery.
I have the shafts cleaned up and the rockers are turning nicely on them now. Once I get everything put back together I'm going to prime the motor and watch all the oiling holes. I'm also going to run some thin wire in the oiling passages on the rockers to make sure they're clear. Not sure what else to do at this point?
Re: Need some Indy cylinder head rocker arm help [Re: mopar dave] #1843386
06/07/15 01:13 PM
06/07/15 01:13 PM
MT PLEASANT, IA
MT PLEASANT, IA
Good to see you around and it has been a while since I've been on the boards. I talked with Scotty a while back and he seems to be doing good. I built a Grand National that I plan to go to the track with. Should make 600 hp at the tire and be good for some easy 10's. I've been neglecting the Cuda for the last 10 years and it's coming back to bite me.
Re: Need some Indy cylinder head rocker arm help [Re: AndyF] #1843409
06/07/15 01:47 PM
06/07/15 01:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Watch the push rod cup at the rocker... if you move
the adjuster up too high the oil that sprays out of
the rocker cant get into the cup(the cup wall will
be blocking it).. when you set it up.. take your time
to check out the oiling.. it will make a mess.. even
with a cut open valve cover.. here is a set of TD rockers..
I think these are off of my W-2... but you can see that they
need a ball and ball push rod.. you can see in the cup of the
rocker the oil supply hole for the push rod.. has another
hole inboard of the roller tip to supply oil the the valve
wave
Re: Need some Indy cylinder head rocker arm help [Re: MR_P_BODY] #1843416
06/07/15 02:03 PM
06/07/15 02:03 PM
MT PLEASANT, IA
MT PLEASANT, IA
That's a good point. I've built 2 engines since this one and spent a lot of time on valve train geometry. Measured for push rods etc. For the life of me I don't remember how we came up with the push rod lengths 10 years ago? I took note on the good rocker and push rods after the valves were set to proper lash before I pulled the rocker arms off. I wanted to see where the adjuster was set when locked down.
Looks like I should be fine with how it was set up. Oil should be getting to the cup at seat and max lift.
Re: Need some Indy cylinder head rocker arm help [Re: BARRACUDA340S] #1843421
06/07/15 02:19 PM
06/07/15 02:19 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Across the counter push rods from Summit range from 7.342 - 7.550 but it's all about valve train geometry. I hate to see you throw your beautiful car back together so quickly.
First, you have aftermarket rockers. They are different than stock so it is necessary to find the correct length pushrod for your combination. Most rocker arm manufacturers want about or no more than 2 threads showing on the bottom of the adjuster. If there are to many threads, the adjuster will be subject to too much pressure. If there are to little threads, the cup will be to high to receive oil from the oiling hole in the rocker arm. Just a guess but I think your original pushrods were too long.
Re: Need some Indy cylinder head rocker arm help [Re: shorthorse] #1843444
06/07/15 02:45 PM
06/07/15 02:45 PM
MT PLEASANT, IA
MT PLEASANT, IA
I hear you about putting it back together so fast but I have to make this show. I can't be sure what caused all the heat. Maybe some of it was starting the motor after letting it sit too long and some heat due to rocker arm oiling? I will put the new parts in it for now and go from there. I'll pull valve covers when I get back from show and just keep an eye on things until I make a decision on what to do.
Re: Need some Indy cylinder head rocker arm help [Re: BARRACUDA340S] #1843445
06/07/15 02:46 PM
06/07/15 02:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In the upper pic the adjuster is up into the
rocker too far... the second one looks ok..set
them basically at 1 1/2 threads showing below
and set up the length with your lash in it.. then
just order the length you need.. in other words.. set the
PR checker then subtract the lash off the checker.. that
way you will be real good on the adjuster
wave
Re: Need some Indy cylinder head rocker arm help [Re: MR_P_BODY] #1843448
06/07/15 02:49 PM
06/07/15 02:49 PM
MT PLEASANT, IA
MT PLEASANT, IA
Will do! Thank you
Re: Need some Indy cylinder head rocker arm help [Re: BARRACUDA340S] #1843460
06/07/15 03:10 PM
06/07/15 03:10 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
7.813" oal, 0.160" cup depth the best I can tell with my caliper. I don't have a ball adapter for it. Diameter is 0.315".
Page 1 of 3 1 2 3
