Tire speed gear ratio calculator #1843341
06/07/15 12:14 PM
06/07/15 12:14 PM
Marilla, New York
RalleyA12 Offline OP
Marilla, New York
Just found this online calculator and thought I would pass it along. Works really great.
http://vexer.com/automotive-tools/speed-rpm-calculator
Re: Tire speed gear ratio calculator [Re: RalleyA12] #1843611
06/07/15 07:26 PM
06/07/15 07:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Has been posted in the tech archives here for years. Tech section has a bunch of good info gathered over time by the members. up
Re: Tire speed gear ratio calculator [Re: RalleyA12] #1843619
06/07/15 07:40 PM
06/07/15 07:40 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's a good one for comparing tire and rims specs:
http://www.rimsntires.com/specspro.jsp
Re: Tire speed gear ratio calculator [Re: autoxcuda] #1843789
06/07/15 10:47 PM
06/07/15 10:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That one should be added to the tech archives also. up
Re: Tire speed gear ratio calculator [Re: RalleyA12] #1843808
06/07/15 10:58 PM
06/07/15 10:58 PM
Thank you for the info. best thing I did was follow Kunkels' advice & measure rollout then divide Pi into it for the actual dia. before that I was placing a piece of flat stock on top of a rear tire & measuring from underneath it to ground with the tire at its psi it reaches when its been ran for awhile.
