1968 roadrunner ground question #1842456
06/05/15 10:05 PM
06/05/15 10:05 PM
Mi
mklott Offline OP
mklott  Offline OP
Mi
Hi I haVe a 68 road runner and I'm having some electrical issues, I think its a ground problem. It seems sometimes things work and then they don't. Wipers will work periodically, same with blower motor, brake lights, and turn signals.I'm thinking I have a ground problem can anybody give me the locations of ground locations to check, also fuel Gage does not work, new sender installed gage reads e when in tank when I pull out and move float it will work correctly I have the ground clip on the fuel line and checked to make sure its grounded and it is but still reads e.
Any help would be appreciated.
Re: 1968 roadrunner ground question [Re: mklott] #1842658
06/06/15 01:22 AM
06/06/15 01:22 AM
South Lyon, Michigan
6bblRoadrunner Offline
I had a similar problem with the fuel gauge on my '69 RR. I compared the oem sender with the reproduction sender and saw that the repro had a nut and washer on the terminal. Not sure why they're on the repro...the terminal is staked on there pretty good. I removed these and the gauge now works. The connector wasn't making contact with the nut on there.
Re: 1968 roadrunner ground question [Re: 6bblRoadrunner] #1842756
06/06/15 10:09 AM
06/06/15 10:09 AM
Ohio
dobie Offline
dobie  Offline
Ohio
That's interesting to hear about the sending unit. I've tried three different brands, all new, and none have ever worked correctly .
1968 Plymouth Road Runner 383 4 speed
Re: 1968 roadrunner ground question [Re: mklott] #1842761
06/06/15 10:34 AM
06/06/15 10:34 AM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
MA Mopar was cheap in the ground area.if you are going for concourse - battery to head and head to fire wall. Stock fuel gauge grounds through the fuel line. If you are doing a show and go car. More grounds are better my 69 bee I got the largest negative cable I could find. I put the battery ground to block instead of head. The cable had a short whip lead. I used that to the radiator support for the headlights more on lights. The head to fire wall I made a thicker cable. I used a repro fuel sending unit and had a friend weld a 1/4 inch tab on it for the ground cable. The cable is screwed to a tad near tank. By passing the fuel line. Please read mad electric amp gauge bypass and headlight relays. We need to fix what MA Mopar did not. I did all the changes on my car and love it.
