Low deck intake options for edelbrock victor heads? #1842403
06/05/15 08:00 PM
06/05/15 08:00 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
My buddy is building a 400 based stroker with cnc potted edelbrock victor heads.
What intake options are out there and how do they stack up?
Thanks!!!
Re: Low deck intake options for edelbrock victor heads? [Re: domingo] #1842533
06/05/15 10:21 PM
06/05/15 10:21 PM
AndyF Offline
AndyF  Offline
Not very many choices for a low deck MW. I covered all of the manifolds in my big block book and I don't think there are any new ones since then.
Re: Low deck intake options for edelbrock victor heads? [Re: domingo] #1842610
06/05/15 11:06 PM
06/05/15 11:06 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I'm using an Indy 4150 single plane with my Edelbrock RPM cnc MW ported heads. I don't know if it would fit the Victor heads though as I don't know much about them.
Re: Low deck intake options for edelbrock victor heads? [Re: domingo] #1842638
06/05/15 11:31 PM
06/05/15 11:31 PM
Are they ported Victors with 440 size ports or the Victor Max Wedge head with the M.W. size ports with additional porting? If Victor M.W. I would look at Indy 400- and 400-3, I used the Indy 400-3(4500 flange) on my current 505 C.I.low deck bracket motor with Victor M.W. unported heads and it does fit well up If not the Victor M.W heads Edlbrock sells a Victor intake for the low decks, I beleive scope
Re: Low deck intake options for edelbrock victor heads? [Re: ProSport] #1842684
06/06/15 01:10 AM
06/06/15 01:10 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
400-2 mocked up to MW port Victors. With a 9.98 deck the port alignment was really good. Everything else has been a complete PIA, but the normally poor port alignment was actually almost perfect.
Humble beginnings:
Re: Low deck intake options for edelbrock victor heads? [Re: Jeremiah] #1842687
06/06/15 01:12 AM
06/06/15 01:12 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
And if you buddy wants to really go for the "Fonzi Effect" he can run one of these:
Re: Low deck intake options for edelbrock victor heads? [Re: domingo] #1843626
06/07/15 06:55 PM
06/07/15 06:55 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks for the infor guys.
It has the MW ports and he wants to run a dominator...so I guess the 400-3 it is with a 4500 flange.
Re: Low deck intake options for edelbrock victor heads? [Re: domingo] #1844021
06/08/15 07:25 AM
06/08/15 07:25 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Indy is the only Max Wedge Low deck intake I know of. I have the 4150 carb flange one, but that is limiting me to a 1,050 cfm 4150 style carb.
I'd like to go to the dual quad, but that's $$$$ I don't have right now.
Re: Low deck intake options for edelbrock victor heads? [Re: domingo] #1844190
06/08/15 01:00 PM
06/08/15 01:00 PM
I've seen several other members on here post saying they used the 400-2 intakes with the tapered dominator adapters to run Dominator carbs on there motors to make them make more power than running the 400-3 with no spacer confused I ended up using and testing both intakes on my old 518 pump gas stroker 400 motor during dyno testing, they where correct about the 400-2 with the tapered adapter compared to the 400-3 with no spacer, once I added a 1.5 inch high reversion spacer the 400-3 made a tiny bit(3 hp, 2 ft lbs. on the average shruggy) more HP and torque then the 400-2 did with the adapter shruggy Buy the 400-3 intake and use a 1.5 or 2 inch spacer with it up twocents
