06 town and country power sliding door #1842120
06/05/15 02:07 PM
06/05/15 02:07 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
our 06 the passenger side door will open by the power button on the remote and shut until it gets about 12 inches from being closed and it stops. I cleaned the track and lubed it all up before and it worked but now its doing it again and the clean and lube wont work. The wire set up I think might be causing the issue. Anyone have experience with that before?
Contact Me about AMD Prices
Re: 06 town and country power sliding door [Re: hotairballoonpilot] #1842263
06/05/15 05:52 PM
06/05/15 05:52 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: 06 town and country power sliding door [Re: hotairballoonpilot] #1842269
06/05/15 06:09 PM
06/05/15 06:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Wow, that is some great info and directions.
Re: 06 town and country power sliding door [Re: stumpy] #1842286
06/05/15 06:42 PM
06/05/15 06:42 PM
South Dakota
South Dakota
thanks I will try to patch the wires. Didn't think I could do that but looks like I can.
corey
Re: 06 town and country power sliding door [Re: hotairballoonpilot] #1842711
06/06/15 03:22 AM
06/06/15 03:22 AM
Whitey Nocar Offline
If you can't find a wiring issue it may need the computer re programmed. Same thing was happening to our old 2011 and dealer told us that's how they fixed it.... Ours would also open just enough for you to start getting out and then close on you
