Need advice on a convertor for my A12 #1842124
06/05/15 02:12 PM
06/05/15 02:12 PM
Wahoo Nebr
vette1986 Offline OP
Wahoo Nebr
Hey guys my A12 is about ready for its trans. Dudek built the engine with a Mr. Six Pack cam and stock manifolds on it and I talked to Dave about a convertor and he said use a Turbo Action 17501 but they are ALL sold out and have been back ordered for months with none in sight.
That is what I would like to run but without one available I called Bob since he made the cam and he is a great guy to talk to and he said get a convertor as close to a stock 383 convertor as the cam likes a tight convertor. He said it does not have to be a big fancy convertor as loose is not good for this cam. Anyone know what the stall on a stock 383 convertor is? And who stocks a comparable convertor?? Thanks for any help
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: Need advice on a convertor for my A12 [Re: vette1986] #1842158
06/05/15 03:15 PM
06/05/15 03:15 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Well, my car isn't an A12 but it is a six pack car with the same camshaft. It was getting to the point where I figured the cam and converter (stock) were a bit of a mismatch as I couldn't get out of the garage without spinning the tires....since then I found my problem was the distributor and minor carb tuning and now the idle is down to 900 rpm it works OK...but I still wonder if I'd have been better off with a slightly higher stall converter to improve driveability...
Bob is a great guy and I've spoken to him a few times; knowledgeable, friendly and very helpful.
2 cents,
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Need advice on a convertor for my A12 [Re: vette1986] #1842187
06/05/15 04:07 PM
06/05/15 04:07 PM
Wahoo Nebr
Wahoo Nebr
I have been eyeing a 2400 stall. What stall do you have? Any idea what stock stall is?
1969.5 A12 Bee EV2
1971 Charger RT
Re: Need advice on a convertor for my A12 [Re: vette1986] #1842256
06/05/15 05:39 PM
06/05/15 05:39 PM
DPelletier Offline
DPelletier  Offline
I'm no expert, it's been quite a few years and I don't have my books and invoices in front of me.....but IIRC, the stall speed for a given converter varies depending on the power of the engine it's bolted too so a "2500" stall converter might stall at 1800 or 2500 rpm depending. Mine is supposed to be a stock converter but as my engine makes more power, the stall speed is lower.
Stock converters were 12" which were supposed to be 1800 - 2100 or 10.5" which were rated at 2100 - 2300. I'm not sure you can compare the "looseness" of the stock ratings vs. the aftermarket.
As I write this, I'm wondering if I was supposed to use the "stock" 10.5 and maybe I ended up with the 12"....that would explain why my higher hp motor was having issues when the idle was up around 1300 - 1400rpm ...
I'm going to see if I can dig out some paperwork to identify it. ....whatever it is, it's too tight for Bob K's Six Pack cam IMO.
Re: Need advice on a convertor for my A12 [Re: vette1986] #1842260
06/05/15 05:43 PM
06/05/15 05:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The converter he recommends is a factory 10 3/4" P/N 2801 764; many rebuilders use the last three digits of the factory number so a quality rebuilt 764 would serve your purposes. Cores are getting hard to find.
Re: Need advice on a convertor for my A12 [Re: vette1986] #1842261
06/05/15 05:44 PM
06/05/15 05:44 PM
DPelletier Offline
DPelletier  Offline
Re: Need advice on a convertor for my A12 [Re: vette1986] #1842285
06/05/15 06:38 PM
06/05/15 06:38 PM
Wahoo Nebr
Wahoo Nebr
I had been eyeing this one on Jegs. I wish I really knew what it would stall at with my setup. The engine was dyno'd and it 462 ft lbs of torque and 416 horse so it is not wild by any means but I wonder what the stall on these convertors was factored with a 350 ft lbs motor??
http://www.jegs.com/i/Hughes-Performance/512/24-25/10002/-1?parentProductId=
1969.5 A12 Bee EV2
1971 Charger RT
Re: Need advice on a convertor for my A12 [Re: vette1986] #1842427
06/05/15 09:27 PM
06/05/15 09:27 PM
Wahoo Nebr
Wahoo Nebr
Can anyone find where a place that has a Turbo Action 17501 in stock?? I think I have melted down my modem looking for one with NO luck.
Anyone have one they put on the shelf and did not use??
1969.5 A12 Bee EV2
1971 Charger RT
Re: Need advice on a convertor for my A12 [Re: vette1986] #1842499
06/05/15 10:50 PM
06/05/15 10:50 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The 17501 is a little loose for that cam. Buy the flex plate and bolts for the 17501 from Turbo Action. It's a 6 bolt flex plate with lugs for the Hemi size TC bolts. You may have more options if you look for a Hemi replacement converter.?
