header spark plug for big block aluminum heads #184148
01/04/09 09:40 PM
01/04/09 09:40 PM
WASHINGTON
superbee471 Offline OP
WASHINGTON
Does anybody know if they make a short header spark plug for the aluminum heads. I have a space problem on the driver side rear two plugs. I used to run Accell on my iron heads but they do not list one for the small block style plugs. If anybody knows of a part number for any brand of plug I could shur use the information.
Re: header spark plug for big block aluminum heads [Re: superbee471] #184149
01/04/09 10:09 PM
01/04/09 10:09 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I do, but I think I would get laughed off Moparts if I said what I had used....
If you want to know what I used, PM me.
Re: header spark plug for big block aluminum heads [Re: superbee471] #184150
01/04/09 11:31 PM
01/04/09 11:31 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
NTOLERANCE - I think most people would welcome the knowledge of what you used. I would, please post it.
What I've often done for other applications is go to a plug vendors website and "pick" the specs I'd like for a plug ... heat range, reach, electrode type, insulator length, etc.. Most manufacturers make every combination of plug you can think of.
Re: header spark plug for big block aluminum heads [Re: Stanton] #184151
01/05/09 12:43 AM
01/05/09 12:43 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I'll post it, but only because you asked
I received this info years ago, and tried it in two mopar big blocks with oem cast iron heads. I havent tried them in aluminum heads, so youre going into uncharted ground there... I was talking to an old time engine builder named Don Dulmage. Google his name, he has a web site. He is retired now, but this is the info he sent me:
For more header room around your spark plugs on your BB Mopar we often use Autolite 2974. Heat range and tip is perfect for these engines and they are barley 1 1/2 " long. Don't ask what they are for, (Does the word lawnmower bear any
significance?) just use and enjoy! We have also used the Bosch although the
crossover number escapes me at the moment. Very good plugs though.
I didnt beleive it myself, but a friend of mine had some headders on a big block truck so we tried them, worked fine. Put them on another car with headders no problems. These werent race only vehicles, more street cars. I would run a whole set, not just a plug or two.
Give it a try.
Doc.
(ducking incase people throw useless chevy parts at me)
Re: header spark plug for big block aluminum heads [Re: NTOLERANCE] #184152
01/05/09 10:11 AM
01/05/09 10:11 AM
Thanks for the info! I'll keep it noted for when I get my MP/Eddy hybrid headed 440 together(if my headers give me fits).
Re: header spark plug for big block aluminum heads [Re: superbee471] #184153
01/05/09 11:10 AM
01/05/09 11:10 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Probably a small engine plug.
Problem is, cast iron heads and aluminum heads take distinctly different plug styles - the aluminum heads take the longer reach, smaller thread plug.
Check this out - this is what I was talking about in my earlier post:
http://www.championsparkplugs.com/sparkplug411_manufacturer.asp?manufacturerID=2
Re: header spark plug for big block aluminum heads [Re: Stanton] #184154
01/05/09 11:57 AM
01/05/09 11:57 AM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Accel makes a "shorty plug" in two heat ranges. That's the good news. The bad is that they are only about 1/8" shorter so they don't help that much.
Re: header spark plug for big block aluminum heads [Re: Classof70Chally] #184155
01/05/09 03:20 PM
01/05/09 03:20 PM
WASHINGTON
WASHINGTON
O.K. what are the numbers? I got the book from accel and I could only find the big block cast iron head versions. i am shur someone makes one just do not know where to find it. Thanks.
Re: header spark plug for big block aluminum heads [Re: NTOLERANCE] #184156
01/05/09 03:25 PM
01/05/09 03:25 PM
WASHINGTON
WASHINGTON
Thanks for the info. I will not throw anything at you .
Re: header spark plug for big block aluminum heads [Re: superbee471] #184157
01/05/09 04:58 PM
01/05/09 04:58 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
One number is a 416s. Check Accels web site, I think they are listed there. Even with the shorties my kid had to ding several tubes on his headers for his Eddy headed stroker motor.
Re: header spark plug for big block aluminum heads [Re: superbee471] #184158
01/05/09 10:11 PM
01/05/09 10:11 PM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
E Brock heads with too big of header caused me to seek out a NGK plug that works well. Will have to pull a boot to get the number. 5/8 tools to change them and I have come up with a few trick ones from a few sources.
Re: header spark plug for big block aluminum heads [Re: dragaddict] #184159
01/06/09 10:54 AM
01/06/09 10:54 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Autolite is Chinese now.
Re: header spark plug for big block aluminum heads [Re: Rug_Trucker] #184160
01/07/09 07:10 PM
01/07/09 07:10 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I thought they were Mexican built?
I am still stuck on Champions...I dunno, they still work for me...
