Any "reviews" of 440 Source fabricated valve covers?
#1840624
06/03/15 04:34 PM
06/03/15 04:34 PM
BradH
I have the same Indy no-logo cast covers for my Victors that I used w/ my Stage VIs. However, if I need more rocker arm clearance w/ the Victors, I was looking at the fabricated covers that 440 Source lists here. Any feedback on fit, construction, leakage issues / concerns, etc., is appreciated. Thanks. - Brad
Re: Any "reviews" of 440 Source fabricated valve covers?
[Re: BradH]
#1840628
06/03/15 04:38 PM
06/03/15 04:38 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I have a set on my Indy SRs and I haven't had any issues. They're pretty well-constructed and they fit pretty well (no leaks).
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: BradH]
#1841084
06/04/15 12:48 AM
06/04/15 12:48 AM
Posts: 15 kansas city mo
turbofreek
kansas city mo
Had a pair on my ol 440. Fit snug and nice.
dont feel like typing it again
[Re: moparlifer]
#1841348
06/04/15 12:54 PM
06/04/15 12:54 PM
BradH
On victor heads with offset rockers, mine hit the pan rail and had to be ground for clearance and I lost a lot of sealing area when done! The description on the page I linked above does mention needing to clearance the rail for Victor heads, so not a surprise. I know some rockers would make that more of an issue than others. EDIT: What about distributor clearance w/ those covers on Victor heads? ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: BradH]
#1841663
06/04/15 08:09 PM
06/04/15 08:09 PM
Posts: 485 Central California
MoParFish
Central California
On victor heads with offset rockers, mine hit the pan rail and had to be ground for clearance and I lost a lot of sealing area when done! The description on the page I linked above does mention needing to clearance the rail for Victor heads, so not a surprise. I know some rockers would make that more of an issue than others. EDIT: What about distributor clearance w/ those covers on Victor heads? My valve covers are procomp which are similar. I also had to clearance the flange so they would drop straight down over the studs without hitting the HS rockers. I use and re-use Felpro blue stripe cork gaskets on valve covers and oil pan with no sealer and no leaks. I use an MSD distributor without issue. Those 440Source covers do look nice with thicker flanges!
