Replacing boosters in 4150 &4500 Holley carbs? #1841215
06/04/15 08:21 AM
06/04/15 08:21 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Has anyone done this themselves? What tools did you need?
Alan Jones
Re: Replacing boosters in 4150 &4500 Holley carbs? [Re: LA360] #1841223
06/04/15 08:41 AM
06/04/15 08:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You should register on racingfuelsystems.myfunforum.org and post your question there. twocents
Re: Replacing boosters in 4150 &4500 Holley carbs? [Re: LA360] #1841246
06/04/15 09:22 AM
06/04/15 09:22 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Booster install tool,it flares the end of the booster and holds it tight to the main body.
Check out this item I found on eBay: http://pages.ebay.com/motors/link/?nav=item.view&id=331368669867&alt=web
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Replacing boosters in 4150 &4500 Holley carbs? [Re: LA360] #1841309
06/04/15 10:51 AM
06/04/15 10:51 AM
P
Porter67 Offline
Porter67  Offline
P
With the proper tool its so easy to do them. If you have the proper tool its quick and easy. If you cant justify the price of the tool you might find a racer who has one and will do yours semi cheap.
Mine looks nearly exactly like the one in the link.
Last time I checked alot of the shops wanted $30 per booster.
Re: Replacing boosters in 4150 &4500 Holley carbs? [Re: LA360] #1841391
06/04/15 12:36 PM
06/04/15 12:36 PM
Mark Whitener Offline
With a Dominator it is just a matter of pulling out the stake tubes, this can be done with a slide hammer, I have a home made puller I use after threading the stake tubes. BLP sells new stake tubes.
A 4150 has to have the boosters swedged in, flared similar to a flaring tool. BLP sells both a hand held tool as well as a mill mount, I have both and both work fine, the mill mount is a tad cleaner on the finish and quicker. I'm sure you could make something in a pinch if you had to, but if you plan do do a bunch the proper tool is the best. There is a home made one in the link below.
http://racingfuelsystems.myfunforum.org/viewtopic.php?f=25&t=824&p=7673
Mark Whitener
[url=www.racingfuelsystems.com[/url]
