Re: cylinder head data for dynosim program to enter needed.
[Re: Dunnuck Racing]
#184105
01/04/09 09:38 PM
01/04/09 09:38 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
The picture you show in the first post is your lifter acceration rate,you can figure it by entering your seat to seat and @.050 duration numbers in the camshaft files. For the head flow chart ,you need to manually enter in correct valve sizes for starters,then enter in the flow at each lift number manually.Do you have a flow sheet for your heads? If not ,you can use a generic head flow chart from the program,but your results won't be as accurate. Hope this helps,...Keith
ya i have my head chart. no hemi chart but wedge,canted,2/4 calve... i am looking for eddie,indy,B1/bs,MC the popular heads to start. i did use the auto select on the lifter,cam info.i will get cam specs out of a cataloge and so on.
[Re: blownzoom440]
#184106
01/04/09 09:47 PM
01/04/09 09:47 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Maybe I misunderstood what you were looking for.Do you want flow numbers from several different heads to compare for your engine?
#184107
01/04/09 09:51 PM
01/04/09 09:51 PM
blownzoom440
ELYRIA,OH
Maybe I misunderstood what you were looking for.Do you want flow numbers from several different heads to compare for you engine?
just to enter for record and to play with.
[Re: blownzoom440]
#184108
01/04/09 09:54 PM
01/04/09 09:54 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
MP '452 Aluminum/Edelbrock RPM (Ported)
___________IN__________________EX
.100".........74.5.........................65.4 .200"........151.1.......................142.9 .300"........219.7.......................171.7 .400"........262.8.......................198.4 .500"........286.8.......................217.5 .550"........294.4.......................223.8 .600"........298.7.......................231.4 .650"........305.2.......................237.0 .700"........307.4.......................241.3
#184110
01/04/09 10:11 PM
01/04/09 10:11 PM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
Here's a spreadsheet I did back in March 2007 from different peoples posts. Use it as reference as I only compiled the data.
Edit: I went back and looked at the thread I created this for and credit for the data should be BMRE's website. I also believe Pete put together a similar sheet after that but couldn't find it.
