cylinder head data for dynosim program to enter needed. #184101
01/04/09 08:59 PM
01/04/09 08:59 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
thanks.including valve size.flow from .100 to max lift of head to .800 if needed.i need the info for better reswults of the program i have.i put in stroker kit info and head data would help.
i dont need curtain area pinch#s...
thanks for any help!
Re: cylinder head data for dynosim program to enter needed. [Re: blownzoom440] #184102
01/04/09 09:04 PM
01/04/09 09:04 PM
ELYRIA,OH
ELYRIA,OH
here is the head chart.
Re: cylinder head data for dynosim program to enter needed. [Re: blownzoom440] #184103
01/04/09 09:21 PM
01/04/09 09:21 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
You need flow data from .100 lift to .700 lift in .100 increments. For what head?? mike
Re: cylinder head data for dynosim program to enter needed. [Re: blownzoom440] #184104
01/04/09 09:28 PM
01/04/09 09:28 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The picture you show in the first post is your lifter acceration rate,you can figure it by entering your seat to seat and @.050 duration numbers in the camshaft files.
For the head flow chart ,you need to manually enter in correct valve sizes for starters,then enter in the flow at each lift number manually.Do you have a flow sheet for your heads? If not ,you can use a generic head flow chart from the program,but your results won't be as accurate.
Hope this helps,...Keith
Re: cylinder head data for dynosim program to enter needed. [Re: Dunnuck Racing] #184105
01/04/09 09:38 PM
01/04/09 09:38 PM
ELYRIA,OH
ELYRIA,OH
ya i have my head chart.
no hemi chart but wedge,canted,2/4 calve...
i am looking for eddie,indy,B1/bs,MC the popular heads to start.
i did use the auto select on the lifter,cam info.i will get cam specs out of a cataloge and so on.
Re: cylinder head data for dynosim program to enter needed. [Re: blownzoom440] #184106
01/04/09 09:47 PM
01/04/09 09:47 PM
Northern Indiana
Northern Indiana
Maybe I misunderstood what you were looking for.Do you want flow numbers from several different heads to compare for your engine?
Re: cylinder head data for dynosim program to enter needed. [Re: Dunnuck Racing] #184107
01/04/09 09:51 PM
01/04/09 09:51 PM
ELYRIA,OH
ELYRIA,OH
Maybe I misunderstood what you were looking for.Do you want flow numbers from several different heads to compare for you engine?
just to enter for record and to play with.
Re: cylinder head data for dynosim program to enter needed. [Re: blownzoom440] #184108
01/04/09 09:54 PM
01/04/09 09:54 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
MP '452 Aluminum/Edelbrock RPM (Ported)
___________IN__________________EX
.100".........74.5.........................65.4
.200"........151.1.......................142.9
.300"........219.7.......................171.7
.400"........262.8.......................198.4
.500"........286.8.......................217.5
.550"........294.4.......................223.8
.600"........298.7.......................231.4
.650"........305.2.......................237.0
.700"........307.4.......................241.3
Re: cylinder head data for dynosim program to enter needed. [Re: S/ST 3040] #184109
01/04/09 10:01 PM
01/04/09 10:01 PM
Northern Indiana
Northern Indiana
Thanks,Vic! Those numbers were after he ported them.Maybe he can post before numbers(ootb)?I remember them as being a little lower than advetised.....Keith
Re: cylinder head data for dynosim program to enter needed. [Re: Dunnuck Racing] #184110
01/04/09 10:11 PM
01/04/09 10:11 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
Here's a spreadsheet I did back in March 2007 from different peoples posts. Use it as reference as I only compiled the data.
Edit:
I went back and looked at the thread I created this for and credit for the data should be BMRE's website. I also believe Pete put together a similar sheet after that but couldn't find it.
Re: cylinder head data for dynosim program to enter needed. [Re: Dunnuck Racing] #184111
01/04/09 10:12 PM
01/04/09 10:12 PM
S/ST 3040 Offline
S/ST 3040  Offline
OOTB MP/452
.............Intake....................................Exhaust
.100"_____66.9_________________________62.4
.200"____141.9________________________121.5
.300"____201.7________________________161.2
.400"____247.8________________________185.6
.500"____270.6________________________200.5
.550"____275.7________________________204.4
.600"____278.6________________________209.6
.650"____278.1________________________213.2
Re: cylinder head data for dynosim program to enter needed. [Re: TS3303] #184112
01/04/09 10:24 PM
01/04/09 10:24 PM
ELYRIA,OH
ELYRIA,OH
and to others with more info!
Re: cylinder head data for dynosim program to enter needed. [Re: blownzoom440] #184113
01/04/09 10:30 PM
01/04/09 10:30 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
see edit above for proper credit for the flow numbers.
