Any "reviews" of 440 Source fabricated valve covers? #1840624
06/03/15 04:34 PM
06/03/15 04:34 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I have the same Indy no-logo cast covers for my Victors that I used w/ my Stage VIs. However, if I need more rocker arm clearance w/ the Victors, I was looking at the fabricated covers that 440 Source lists here.
Any feedback on fit, construction, leakage issues / concerns, etc., is appreciated. Thanks. - Brad
Re: Any "reviews" of 440 Source fabricated valve covers? [Re: BradH] #1840628
06/03/15 04:38 PM
06/03/15 04:38 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I have a set on my Indy SRs and I haven't had any issues. They're pretty well-constructed and they fit pretty well (no leaks).
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Any "reviews" of 440 Source fabricated valve covers? [Re: BradH] #1841084
06/04/15 12:48 AM
06/04/15 12:48 AM
kansas city mo
turbofreek Offline
turbofreek  Offline
kansas city mo
Had a pair on my ol 440. Fit snug and nice.
dont feel like typing it again
Re: Any "reviews" of 440 Source fabricated valve covers? [Re: BradH] #1841225
06/04/15 09:51 AM
06/04/15 09:51 AM
BradH Offline OP
BradH  Offline OP
Thanks for the replies. They sound like a decent alternative if the Indy cast covers have any clearance issues.
Re: Any "reviews" of 440 Source fabricated valve covers? [Re: BradH] #1841321
06/04/15 12:10 PM
06/04/15 12:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I broke my dr. side cast Mopar performance v-c around the outer bolt and now it leaks a bit and need good covers that clear HS rockers. Do these clear by chance? thumbs
Re: Any "reviews" of 440 Source fabricated valve covers? [Re: BradH] #1841324
06/04/15 12:13 PM
06/04/15 12:13 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
On victor heads with offset rockers, mine hit the pan rail and had to be ground for clearance and I lost a lot of sealing area when done!
Re: Any "reviews" of 440 Source fabricated valve covers? [Re: moparlifer] #1841348
06/04/15 12:54 PM
06/04/15 12:54 PM
BradH Offline OP
BradH  Offline OP
The description on the page I linked above does mention needing to clearance the rail for Victor heads, so not a surprise. I know some rockers would make that more of an issue than others.
EDIT: What about distributor clearance w/ those covers on Victor heads? work
Re: Any "reviews" of 440 Source fabricated valve covers? [Re: Thumperdart] #1841350
06/04/15 12:55 PM
06/04/15 12:55 PM
BradH Offline OP
BradH  Offline OP
Based on how the pics show they flair out from the base compared to my Indy cast covers, I'd say they'd provide more room than your MP covers.
Re: Any "reviews" of 440 Source fabricated valve covers? [Re: BradH] #1841365
06/04/15 01:09 PM
06/04/15 01:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good 2 know........Thankxxx....... thumbs
Re: Any "reviews" of 440 Source fabricated valve covers? [Re: BradH] #1841663
06/04/15 08:09 PM
06/04/15 08:09 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
My valve covers are procomp which are similar. I also had to clearance the flange so they would drop straight down over the studs without hitting the HS rockers. I use and re-use Felpro blue stripe cork gaskets on valve covers and oil pan with no sealer and no leaks. I use an MSD distributor without issue. twocents thumbs
Those 440Source covers do look nice with thicker flanges!
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
