1984 Ram dash removal stupid question....
#1840250
06/03/15 02:37 AM
06/03/15 02:37 AM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
Can you remove the entire dash - for instance like a 71 Charger - without removing the windshield? Someone told me its impossible; that the windshield must be removed to access all the bolts/screws to remove the dash.
Please advise.
Thanks, Ron
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 1984 Ram dash removal stupid question....
[Re: WyleECoyote]
#1840935
06/03/15 10:45 PM
06/03/15 10:45 PM
Posts: 15,487 Florida
scratchnfotraction
if you cut the inside of the gasket in a nice big V shape at each screw across the top you could then use a 5/16" hex bit on 1/4" flex drive.
2 nuts/studs at colum & 2 bolts on each lower corner in the kick panel.
the dash rolls down from colum and out leaving the a/c heater box in place.
oh yea, for got the middle support brace that has a couple nuts that you can forget to remove.
best way to remove the windshield it to use a 10" butcher knife to lay flat on glass and cut the rubber gasket in 1/2 then remove glass.
I suggest new gasket and 50 bucks to a glass man for install.
clean & inspect the roof drip rail and pinch weld for gasket. repair as needed first.
[Re: Golden-Arm]
#1845205
06/09/15 08:15 PM
06/09/15 08:15 PM
WyleECoyote
Tennessee
Wow - thanks for all the replies guys! Helps me a lot.
Sorry for the delayed reply; I haven't logged on in a few days.
