Re: Overheating issues in 508
[Re: MikeyT]
#1839653
06/02/15 12:33 PM
06/02/15 12:33 PM
Posts: 15,357 Omaha Ne
TJP
Omaha Ne
For maximum effect the fan should be about 1/2 way in the shroud opening. How many blades on the 17" fan and what style???? How much distance between the tips of the blades and the shroud ID???? Another thing to try is to put a towel on the front of the radiator with the engine idling to try and establish how much air is being drawn across the core. I agree with the others that it the symptoms indicate inadequate air flow through the radiator
[Re: MikeyT]
#1839674
06/02/15 01:07 PM
06/02/15 01:07 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
good idea, I was thinking the same thing too John double R! Also, I was wondering if my 3600 stall ptc converter might need a separate cooler to relieve the temp on the radiator.
Mikey Adding one is not a bad idea, the added heat load of the trans is not helping, BUT it's not adding much of a heat load at idle. Check the flow thru the rad first as suggest with a towel.
[Re: JohnRR]
#1839690
06/02/15 01:26 PM
06/02/15 01:26 PM
TJP
Omaha Ne
[Re: MikeyT]
#1839962
06/02/15 08:08 PM
06/02/15 08:08 PM
Posts: 2,466 Answering the call of the wild
ThermoQuad
Wrong thermostat 195 degrees required to properly burn today's fuel. Below 195 fuel collects in the intake and burns off in the cruise mode...a-f goes lean. Gee whiz Mr Wizard how do you know that?...Inovate AF gage and experience. OP where is your temp? See below. Are you at 240? 195 degrees is not hot 210 degrees is not hot 195-215 degrees is normal 220 degrees is warm 230 degrees is really warm 240 degrees is hot Wrong Fan use the jaguar [short] fan clutch and the stock fan Coolant 60% h2o and 40% coolant and the additive like water wetter.
[Re: BSB67]
#1840080
06/02/15 10:31 PM
06/02/15 10:31 PM
TJP
Omaha Ne
Step one, determine if you have an overheating problem.
You have said nothing for me to believe that you have an over heating problem. It gets up to the middle of the factory gauge has no meaning. Buy a good mechanical gauge and collect real temperature data.
Confirm it, then solve it A very valid comment But we do not rely on gauges PERIOD!!! Thermocouples with a good digital temp meter will DEFINTIELY separate the facts and numbers. I have seen gauges regardless or quality or type be off by as much as 60 degrees, typically at the higher end of the scale. In all honesty the ching chong dime a dozen gauges are sometimes more accurate. Kudo's to BSB67 for reading through the lines of this thread
[Re: MikeyT]
#1840173
06/03/15 12:06 AM
06/03/15 12:06 AM
Posts: 7,664 IN
ahy
IN
Ok, fan shroud is on, took it for a cruise last night. It seems somewhat better but was still warming up to about right in middle of my factory gau. I think it would of kept going Ok, so shroud helped but did not fix it Mikey Ok so parts Champion 26 radiator 4 core Fan shroud 17 inch mechanical blade 440souce housing passenger side outlet 440source water pump Timing 24* initial 34* total J Was the cruise around town and stop and go? or rolling 40 MPH plus most of the time? My favorite cooling test is 1) run it on the highway fast as possible without gathering attention of a trooper for at least 10 miles and watch it. Does it stabilize at a reasonable temp? 2) Pull off at the next exit and park with engine running. The engine will be good and warm at that point and watch it. Does it stabilize at a reasonable temp? I would consider 210 F OK in that situation, 220 F marginal. "Middle of the gauge" does not sound bad but you thought it was still climbing? If there is any question about the gauge, an inexpensive mechanical version from the AP store makes a good diagnostic... even if you tape it to your windshield for test.
[Re: MikeyT]
#1840489
06/03/15 02:26 PM
06/03/15 02:26 PM
Posts: 1,377 Back In Iowa
belv2vert66
Back In Iowa
Good idea on the gauge.
Myself, when it comes to cooling, I have been through this all also. If it were my car, I would:
Confirm temp with a gauge,
Confirm tune
Call Glen Ray and get a factory style radiator built. They will do one without all the date codes etc. so you can save a few bucks there but they are not cheap. Get the right shroud, fan and pulley's . As mentioned, all the places that were sealed from the factory are good to have in place and are designed to make the air flow through the radiator.
If that doesn't do it I would go after the WP housing and run a flow cooler WP.
I run a 496 with the Glenn Ray radiator, factory stuff for the rest other than the flow cooler WP and I ran on the thermostat idling in the staging lanes a couple weeks ago at the track. 90 degree day. I am so sold on this set up that I am using the same thing on the 543 going in my coronet.
Good luck ! Nothing worse than sitting at a light watching the temp creep up, wishing the light would change, the slow driver would speed up, the 18 wheeler could make his left turn faster when you are stuck behind him etc etc.
