Re: 03 DODGE RAM FRONT END SHIMMY
[Re: POZEST]
#184003
01/04/09 11:24 PM
01/04/09 11:24 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
Could be the track bar. I have seen ball joints on the aam axles go out at 40k also.
Josh
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
[Re: Jambbii]
#184004
01/04/09 11:38 PM
01/04/09 11:38 PM
Posts: 2,505 God's Country Maryland
GODSCOUNTRY340
It's either the track bar or the steering stabilizer. You may still have a bad stabilizer, I've seen new ones that were junk.
[Re: Lefty]
#184006
01/05/09 01:51 AM
01/05/09 01:51 AM
Posts: 4,085 The Wet Coast, Canada
megajoltman
also as said really give the track bar a "going over" it may look fine but check if its worn out and check the front end alignment.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
[Re: ekim]
#184009
01/05/09 05:14 PM
01/05/09 05:14 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Buildanother and Lefty are right: - You will get all kinds of diagnosis' and some of them might even get the problem to go away....for awhile. You have Death Wobble (or DW for short) it isn't limited to 3rd gens as lots of 2nd gen trucks do it as well as Fords and Jeeps. Things like lift kits, large load range D tires, front end leveling kits, worn steering stabilizers, track bars and other front end components can set it off, BUT the underlying cause is the design of the suspension itself coupled with improper caster settings. You'll get many people telling you that shocks or tires or trackbars "cured" the problem for them, but I would contend that they've put the problem in "remission" and the underlying condition will manifest itself again once there is some more play in the system. All you do by changing shocks (for example) is close the "path of least resistance". My advice: replace any or all worn components and have a competant alignment shop dial in the appropriate positive caster: NOT "within tolerances" according to DC, the proper amount (sorry don't remember the exact figure). If you want to learn more go here: www.turbodieselregister.com , pay your $40.00 and search Death Wobble in the archives. Make sure you have coffee and plenty of time. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: moparmandc]
#184012
01/05/09 08:18 PM
01/05/09 08:18 PM
DPelletier
With all due respect, there are a number of things that can make the problem go away for awhile, including work described in TSB 22-005-06, but trust me: it's an alignment issue; usually not enough positive caster. I've been over this a 1000 times and people will still go ahead and buy new (insert here trackbar/balljoints/shocks/tires/whatever) and claim that the problem is "fixed". That's just not the case. No new steering damper or whatever is going to "fix" Death Wobble.....although it may not show up for awhile. This is nothing new and the Jeep guys have been dealing with this forever. In my impromptu investigation, the vast majority of DW complaints came from guys who used the 2" front leveling kit (guess that changes the caster specs, huh!) and larger load range D tires (usually 315 BFG's) or some other lift kit. Here's some good reading although I would suggest that some of the reasons listed aren't really the root cause, but rather the weak link (the text points that out in at least one case); http://www.yuccaman.com/jeep/dw.html + Dave
1974 'Cuda
