Re: Hemi valve cover clearance
[Re: turbogmc]
#1841241
06/04/15 10:14 AM
06/04/15 10:14 AM
Posts: 13,368 Marion, South Carolina [><]
an8sec70cuda
I have the Indy cast valve covers on the hemi in my '70 cuda and had to dent in the shock tower for clearance.
[Re: turbogmc]
#1841272
06/04/15 11:13 AM
06/04/15 11:13 AM
Posts: 12,133 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you raise the engine, keep in mind that the drive train angle will be impacted. Just something else to have to deal with.
On mine, I moved the pass shock over about 3/4" and made a notch in the shock tower rather than beat it into submission. I still have to loosen the pass mount and jack the engine up to get the valve cover off.
Master, again and still
[Re: DaveRS23]
#1841901
06/05/15 01:49 AM
06/05/15 01:49 AM
Posts: 1,805 ky hills
thehemikid
ky hills
Are the Indy's bigger than the Stage V's Probably not much help, but fwiw... ...The Stage V's clear the rh shock tower in my 70RR but not by much. iirc the shock wasn't in when I put the v/c on. Haven't put a load on this motor yet,... it may hit. Heater hoses are a bit close. Battery is a bit close even though it's moved as far as it'll go towards the fender. And the battery tray had to be trimmed I had to lower the rear of the motor at the trans cross mount just a bit to get the passenger side tti collector off the T-bar. Really didn't want to, but gotta do something, & that helped with the heater hoses some. Mega Parts Hemi K & stock mounts & brackets.
[Re: turbogmc]
#1843273
06/07/15 05:55 AM
06/07/15 05:55 AM
thehemikid
ky hills
Some drawbacks to the Stage V's: 1) They like the "correct" upper tube seals from John Arruzza. http://www.arruzzahighperformance.com/Parts/Parts.htmlScroll down about 11 pages worth. 2) The tube doesn't stick up past the cover to help catch the hat to keep it centered. So the hat may vibrate off center a little depending on your hat adjustment on the wire. You'll notice some of mine are a little sunk in to keep them tight. The motor in my pic's hasn't been on the road yet. Not sure yet if they'll stay put. They have with cooling system tests, with the car in the shop. ymmv
