Page 8 of 48 1 2 6 7 8 9 10 47 48
Re: Modern Bullitt build [Re: Keepat] #1837353
05/30/15 04:10 PM
05/30/15 04:10 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Ralph,
I have the angle of the of the trans set the same as the stock trans and will adjust to the rear as it will be lower then stock by 2" +/-
Pat
Re: Modern Bullitt build [Re: Keepat] #1838624
06/01/15 01:00 PM
06/01/15 01:00 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The biggest part of the trans tunnel is finished and all that is left is lifting the aft end of the tunnel to meet the new height of the trans tunnel. But before that I’m starting on the cross member that will be made from 3/8 aluminum, I’ll post a few drawings of the cross member design soon.
Pat
Re: Modern Bullitt build [Re: Keepat] #1841010
06/03/15 11:48 PM
06/03/15 11:48 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Test fit the TTI headers and they fit great! Left side just touches the corner of the starter but there are no gasket installed yet and should clear when in. I also started on the cross member by making a plywood template. I should have it mocked up over the weekend and make the aluminum cross member next week.
Pat
Re: Modern Bullitt build [Re: Keepat] #1843330
06/07/15 11:41 AM
06/07/15 11:41 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I finished mocking up the cross member with plywood and will duplicate in aluminum. This design will eliminate the need for the over the trans cross member. I think with a few modifications this cross member could also be used with a stock torsion bar suspension as well.
Pat
Re: Modern Bullitt build [Re: Keepat] #1847870
06/13/15 01:33 AM
06/13/15 01:33 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Had a friend weld the aluminum cross member for me and I think it looks great! With a little adjustment it fit as good as it looks!
Pat
I add a flange at each end and I need to weld on the end caps to the original cross member. Also reused the original crush brace for the new hole I added for the cross member.
Re: Modern Bullitt build [Re: Keepat] #1848085
06/13/15 02:28 PM
06/13/15 02:28 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
For anyone interested here is a drawing of how I think this cross-member could be made to work with a stock torsion bar suspension.
Pat
Re: Modern Bullitt build [Re: Keepat] #1848403
06/13/15 11:36 PM
06/13/15 11:36 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I always look forward to your posts and pic updates.. Amazing ideas and fab work...
Re: Modern Bullitt build [Re: minivan] #1848406
06/13/15 11:45 PM
06/13/15 11:45 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir, I'm glad you enjoyed it.
Pat
Re: Modern Bullitt build [Re: Keepat] #1849191
06/14/15 11:32 PM
06/14/15 11:32 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Cut the aft end of the trans tunnel and tacked it in place and now it is looking close to original.
Pat
Re: Modern Bullitt build [Re: Keepat] #1849219
06/15/15 12:08 AM
06/15/15 12:08 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Is anybody else following this thread and thinking 'damn there are people on Moparts with amazing automotive skills' ?
Re: Modern Bullitt build [Re: Pacnorthcuda] #1849465
06/15/15 11:36 AM
06/15/15 11:36 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Yes....
Ed
Re: Modern Bullitt build [Re: Keepat] #1850168
06/16/15 01:22 AM
06/16/15 01:22 AM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
yep
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: Modern Bullitt build [Re: Pacnorthcuda] #1850369
06/16/15 11:55 AM
06/16/15 11:55 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Effin A... I know how much time and labor it took just to take one apart and put it back together like the factory did.. Lots of wire wheel time.....
Re: Modern Bullitt build [Re: Keepat] #1850594
06/16/15 05:52 PM
06/16/15 05:52 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you gentlemen! I'm glad you enjoyed it, thanks for following the progress.
Pat
Re: Modern Bullitt build [Re: Keepat] #1851370
06/17/15 10:13 PM
06/17/15 10:13 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
A few pictures of the new cross member installed with the transmission.
Pat
Re: Modern Bullitt build [Re: Keepat] #1853614
06/21/15 01:56 AM
06/21/15 01:56 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I made a shifter cover with a similar shape as an original 4 speed cover using a wood block and a press. This will cover will be removable for shifter access.
Pat
Re: Modern Bullitt build [Re: Keepat] #1854716
06/22/15 09:23 PM
06/22/15 09:23 PM
Valley of the sun, AZ
2
2JcodeChargers Offline
Holy crap!
Pat, you're the man.
Re: Modern Bullitt build [Re: Keepat] #1854790
06/22/15 10:56 PM
06/22/15 10:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
This is the shifter that came with the T56 and I would like to find an original 1968 T handle shifter that I can modified the T handle to trigger a relay for the reverse lockout on the new trans. If anyone has one or knows where to get one please let me know. I’ll check at Carlisle in a few weeks.
Pat
Re: Modern Bullitt build [Re: Pacnorthcuda] #1857470
06/26/15 04:13 PM
06/26/15 04:13 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
yup!
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Modern Bullitt build [Re: Keepat] #1858144
06/27/15 02:12 PM
06/27/15 02:12 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
This is looking great Pat. You are an inspiration to just make it work.
