Page 4 of 6 1 2 3 4 5 6
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: dart4forte] #1838393
06/01/15 01:53 AM
06/01/15 01:53 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I read somewhere, perhaps here on Moparts, that the earlier years used the stamped blades and later used ink.
Not sure if by later meant 70-71 up ?.
Perhaps it had to do with AC as well.
The majority of AC cars I have seen had the stamped numbers.
Could also have been more than one vendor for the blades, one stamping them, one using ink.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1838409
06/01/15 02:28 AM
06/01/15 02:28 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
And I heard the same but based on Barry's 70 examples (stamped in metal) vs. my ink stamped examples, I'm not sure which happened when or why. As you mentioned, a second vendor could easily be the case.
If any of you guys have any 216 or 215 blades (stamped either way) and know what year car etc. they came off of, please post your examples.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1843913
06/08/15 12:59 AM
06/08/15 12:59 AM
FL
moparwizard Offline
moparwizard  Offline
FL
71 cuda 340 4speed no A/C 923 SPD stamped in metal blades
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1843937
06/08/15 01:42 AM
06/08/15 01:42 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks Wizzard, perfect example!
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1851618
06/18/15 04:45 AM
06/18/15 04:45 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This is a 215 fan from my 69 340 4-speed with factory air. 69 340s with no air had the same 215 fan. But only 340s with air did have this thermal fan clutch part 2863263 (except clutch 2863266 if 2.76 axle). Non air 340s had a different non-thermal fan clutch. The only marking I found anywhere on the fan assembly is this 46237 emboss on the hub.
This fan clutch is a parts counter replacement date coded 7/30/73 (G30=7/30, year=DB?) but otherwise identical to a 69 factory Eaton part, according to Pampered Corvettes, who recently restored it with a date code preceding my SPD 11/8/68.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1869907
07/14/15 01:14 AM
07/14/15 01:14 AM
Sacramento,California
JRepucci Offline
JRepucci  Offline
VIN# 1B212538 approx. SPD 11/15/70
block casting date 7/2/70
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: JRepucci] #1869908
07/14/15 01:15 AM
07/14/15 01:15 AM
JRepucci Offline
JRepucci  Offline
1B212538
picture post #2
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: JRepucci] #1869912
07/14/15 01:17 AM
07/14/15 01:17 AM
JRepucci Offline
JRepucci  Offline
1B212538
picture post #3
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: JRepucci] #1869914
07/14/15 01:20 AM
07/14/15 01:20 AM
JRepucci Offline
JRepucci  Offline
1B212538
Picture post #4
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: JRepucci] #1869915
07/14/15 01:22 AM
07/14/15 01:22 AM
JRepucci Offline
JRepucci  Offline
1B212538
Picture post #5
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1869958
07/14/15 02:26 AM
07/14/15 02:26 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Jason, any paint on the dist hold down bolt? Possibly a filter attached before paint? A mask at minimum
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1870192
07/14/15 05:21 PM
07/14/15 05:21 PM
JRepucci Offline
JRepucci  Offline
Scott, pictures and info needed for 71 340
throttle return spring bracket
auto trans kick down linkage
727 shift and pressure levers
lower alternator adjust bracket... non A/C
lower crank pulley
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1872919
07/18/15 03:15 PM
07/18/15 03:15 PM
Smithfield Virginia
V
Va58 Offline
Va58  Offline
V
Smithfield Virginia
Doing resto on 1972 Duster 340 4 speed car. Hundreds of photo's of several
original cars including my buddy Dave's black low mile Duster
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1872930
07/18/15 03:24 PM
07/18/15 03:24 PM
Smithfield Virginia
V
Va58 Offline
Va58  Offline
V
Smithfield Virginia
Now just need to figure out how to post some pics. Been reading post on here forever and also recovering from cancer so my car's resto as slowed down for now but still read a lot of posts. this is a subject I can contribute too.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1872975
07/18/15 04:46 PM
07/18/15 04:46 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
Welcome to the party Scott Harms!
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: dmoore] #1873012
07/18/15 05:46 PM
07/18/15 05:46 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Dmoore, not sure I follow you? I started this thread quite some time ago shruggy
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1873245
07/18/15 11:52 PM
07/18/15 11:52 PM
Hilliard, Ohio
GKMOPAR Offline
GKMOPAR  Offline
Hilliard, Ohio
Va58, working on a 72 Demon 340 4 spd. Would love to see some of your original pictures.
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: GKMOPAR] #1873332
07/19/15 03:29 AM
07/19/15 03:29 AM
Smithfield Virginia
V
Va58 Offline
Va58  Offline
V
Smithfield Virginia
gk, get your email to me and will send to you..
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1873795
07/19/15 09:24 PM
07/19/15 09:24 PM
dmoore Offline
dmoore  Offline
72 Duster340,auto,3.23 SPD of 419, non-ac car, 36,000 miles...
And fan clutch...#2863233 6"
Re: Totally Anal Small Block Details- 318/340/360 1972 & Up [Re: ScottSmith_Harms] #1873822
07/19/15 09:48 PM
07/19/15 09:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Interesting, your 72's fan blades have stamped numbers (not ink stamped). My 71's was ink stamped. Since I've seen both versions on multiple years it points towards more than more than one supplier.
