Re: Holley Economaster carbs?
[Re: volaredon]
#183827
01/04/09 05:27 PM
01/04/09 05:27 PM
RapidRobert
I remember when they came out & were touted as a beneficial mileage addition that many of the circuits were geared specifically for increased mileage via better metering. a parts man years later opinionated that they were problematic that there was a design flaw(& this guy was pretty sharp, had alot of experience(as parts men go ![](/ubbthreads/images/graemlins/wink.gif) ) With that being said I have never used one or talked to anyone who has as they never were widespread for some reason but I would definitely use one if I had the opportunity
[Re: GMP440]
#183829
01/04/09 07:27 PM
01/04/09 07:27 PM
Posts: 2,278 ILLINOIS
volaredon
ILLINOIS
Yes. I have used one on my 68' Coronet with 318. They get very good gas mileage. I used one from 79' till 84'. Then I changed it out for a Holley 500 CFM 2bbl. The Economaster is very good on gas. I believe they are 300 or 350 CFM. Should have no trouble getting at least 20mpg or better on the highway with one of these. I had a lot of good luck with this carb. I still have it in a box. I can't tell you the performance difference from the original Carter 2bbl carb. When I got the car in 79' the Holley Economaster was on it. Set up right it will spin the tires but it will not pin you to the seat with the acceleration. It's just a gas mileage carb. Borg Warner lists carburetor parts for Holley's and other carb brands. I actually have their parts book.
Thanks for the info; what are you gonna do with the one on your shelf? Direct fit for Mopar linkage? Most info I see is 450 CFM. Sounds like it'll be a help on my truck.
[Re: 70dart360]
#183832
01/04/09 08:49 PM
01/04/09 08:49 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
There is a NOS one on Ebay right now with $150 buy it now. 2 hours and 40 minutes to go.
It would make a nice slant carb. I think the seller can get kits.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#183837
01/04/09 09:51 PM
01/04/09 09:51 PM
volaredon
ILLINOIS
IIRC they had 4bbl versions of the Economaster.
I know about the 4 barrel ones; both of these are 4 bbl econ's.
so kits are hard to come by? for what I have in them, if they are scrap no big deal.
[Re: Rug_Trucker]
#183839
01/04/09 10:40 PM
01/04/09 10:40 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I had a 79 Volare with the "Super Six" deal.I ordered a Holley Economaster for a 69 318 car and put the Holley on in place of the OEM Carter.HUGE difference in mileage and that car ran a lot better.I also tried the 4bbl version on my Lil Red Express,but went back to the TQ,as I liked the power I had with the TQ.
