Holley Economaster carbs? #183825
01/04/09 04:40 PM
01/04/09 04:40 PM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
Anyone have experience with them or opinions on them in a daily driven 318 compared to the stock 2 barrel setup in MPG or power? Any parts (kits floats choke pull offs elec choke conversion kits) Where? I went and looked thru a phone book sized Holley catalog at the parts store, that does not mention these carbs even in the "parts" section; also the only number I can find starts with an "L" yet all the Holley carb numbers in the book started with an "R" when I went to look for a rebuild kit.
I am considering using one in a Magnum head conversion on my 83 D 250.. Have 2 of these carbs, that need gone thru; Daily driven, heavy truck, not "used" as a truck ~85% of the time, looking for "just that little bit" more power while retaining the same or (hopefully) better fuel mileage. Dead stock, unrebuilt shortblock; though with the Magnum heads I will be using 1.6 Magnum valve gear. (will "wake up" that stock 318 2 barrel cam, even if just a little)
Re: Holley Economaster carbs? [Re: volaredon] #183826
01/04/09 05:25 PM
01/04/09 05:25 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The fan style boosters were known for getting plugged, once that happened the carb is pretty much junk...
Re: Holley Economaster carbs? [Re: volaredon] #183827
01/04/09 05:27 PM
01/04/09 05:27 PM
I remember when they came out & were touted as a beneficial mileage addition that many of the circuits were geared specifically for increased mileage via better metering. a parts man years later opinionated that they were problematic that there was a design flaw(& this guy was pretty sharp, had alot of experience(as parts men go ) With that being said I have never used one or talked to anyone who has as they never were widespread for some reason but I would definitely use one if I had the opportunity
Re: Holley Economaster carbs? [Re: volaredon] #183828
01/04/09 05:40 PM
01/04/09 05:40 PM
GMP440 Offline
GMP440  Offline
Yes. I have used one on my 68' Coronet with 318.
They get very good gas mileage. I used one from 79' till 84'. Then I changed it out for a Holley 500 CFM 2bbl.
The Economaster is very good on gas. I believe they are 300 or 350 CFM. Should have no trouble getting at least 20mpg or better on the highway with one of these. I had a lot of good luck with this carb. I still have it in a box.
I can't tell you the performance difference from the original Carter 2bbl carb. When I got the car in 79' the Holley Economaster was on it.
Set up right it will spin the tires but it will not pin you to the seat with the acceleration. It's just a gas mileage carb.
Borg Warner lists carburetor parts for Holley's and other carb brands. I actually have their parts book.
Re: Holley Economaster carbs? [Re: GMP440] #183829
01/04/09 07:27 PM
01/04/09 07:27 PM
ILLINOIS
V
V
ILLINOIS
Thanks for the info; what are you gonna do with the one on your shelf? Direct fit for Mopar linkage? Most info I see is 450 CFM. Sounds like it'll be a help on my truck.
Re: Holley Economaster carbs? [Re: volaredon] #183830
01/04/09 07:37 PM
01/04/09 07:37 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
IIRC they had 4bbl versions of the Economaster.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Holley Economaster carbs? [Re: Rug_Trucker] #183831
01/04/09 08:24 PM
01/04/09 08:24 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I have 3 of them, cant get kits for them and every one I ever saw was basically junk. Lotsa stuff clogged up and corroded on them.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Holley Economaster carbs? [Re: 70dart360] #183832
01/04/09 08:49 PM
01/04/09 08:49 PM
Rug_Trucker Offline
Rug_Trucker  Offline
There is a NOS one on Ebay right now with $150 buy it now. 2 hours and 40 minutes to go.
It would make a nice slant carb. I think the seller can get kits.
Re: Holley Economaster carbs? [Re: Rug_Trucker] #183833
01/04/09 09:10 PM
01/04/09 09:10 PM
GMP440 Offline
GMP440  Offline
I did'nt know they flowed 450 CFM. I don't think they flow that much. I could be wrong. They are a direct bolt-on to the throttle linkage and kick down linkage. I was planning on holding on to mine in case gas prices do that big jump again.
Re: Holley Economaster carbs? [Re: GMP440] #183834
01/04/09 09:17 PM
01/04/09 09:17 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Popular Haotrodding did a Monte Carlo with one of these carbs, Edelbrock SP2P, and RV type cam back in the 70's. It was called "Project Econoperformer"
Re: Holley Economaster carbs? [Re: Rug_Trucker] #183835
01/04/09 09:31 PM
01/04/09 09:31 PM
GMP440 Offline
GMP440  Offline
Did some checking. The 450 CFM Economasters are 4bbl carbs. 300-350 CFM are on the 2bbl carbs.
Re: Holley Economaster carbs? [Re: 70dart360] #183836
01/04/09 09:35 PM
01/04/09 09:35 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
we installed alot of them back in the 70's. Most worked fine. But when they went south there was no fix for them. No kits available for them.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Holley Economaster carbs? [Re: Rug_Trucker] #183837
01/04/09 09:51 PM
01/04/09 09:51 PM
ILLINOIS
V
V
ILLINOIS
I know about the 4 barrel ones; both of these are 4 bbl econ's.
so kits are hard to come by? for what I have in them, if they are scrap no big deal.
Re: Holley Economaster carbs? [Re: volaredon] #183838
01/04/09 10:11 PM
01/04/09 10:11 PM
Rug_Trucker Offline
Rug_Trucker  Offline
still no bidders on the one on EBay
Re: Holley Economaster carbs? [Re: Rug_Trucker] #183839
01/04/09 10:40 PM
01/04/09 10:40 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I had a 79 Volare with the "Super Six" deal.I ordered a Holley Economaster for a 69 318 car and put the Holley on in place of the OEM Carter.HUGE difference in mileage and that car ran a lot better.I also tried the 4bbl version on my Lil Red Express,but went back to the TQ,as I liked the power I had with the TQ.
Nautilus Racing-
Re: Holley Economaster carbs? [Re: Chris2581] #183840
01/05/09 11:47 AM
01/05/09 11:47 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Works as advertised /6 or 318 etc
