Baffles with spray bars #183821
01/04/09 04:16 PM
01/04/09 04:16 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Indy valve covers with jesel valve gear & spray bars.
Anyone got any pics on the baffles used under the valve covers? , got the breathers from top of valve cover dumping under the chassis rails , need fix up some baffles under there but pretty tight with spray bars & clearance from the roller rockers.
Don't like the closed type grommets as they fall to bits after a while.
TIA
Re: Baffles with spray bars [Re: 602heavy] #183822
01/04/09 04:54 PM
01/04/09 04:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I just ran to shogun breathers and Indy supplied me baffle plates which as I recall were made by Moroso.
Re: Baffles with spray bars [Re: 602heavy] #183823
01/04/09 04:57 PM
01/04/09 04:57 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Moroso # 68790
