who has the best rear disc brake conversion kit
#183799
01/04/09 03:52 PM
01/04/09 03:52 PM
what do you guys think? I want to put rear disc set up on a 68 convert baracuda?
thanks
Mike
Re: who has the best rear disc brake conversion kit
#183803
01/04/09 11:02 PM
01/04/09 11:02 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I've got the Dr. Diff 11.7 kit. Haven't got the car on the road yet, but it's very easy to install.
In fact, it's so easy to install that my 4 year old daughter could do it...
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: Ludington1]
#183805
01/04/09 11:53 PM
01/04/09 11:53 PM
471Magnum
Space Station #5
I think you should be able to just swap out the drums... and add a proportioning valve. But why bother? If you want upgraded performance, you need to start up front.
You'll also need green bearings. I think ALL rear disc kits require green bearings.
-Jim
[Re: 471Magnum]
#183807
01/05/09 12:07 AM
01/05/09 12:07 AM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
Thanks for the replies... I finally have a Dana 60 ready to put back in the car since it was removed in 1981. I'd like to use the DrDiff front and rear kits, but thought it would help spread the cost out a bit if I could put on the rears now when I put in the Dana without changing much else, instead of bothering to build the current rear drums and put in the Dana just to replace them later with the rear discs. Wait a bit to absorb the cost of the rear discs and then do the fronts and new master cylinder. Just curious if I'd run into any problems doing it that way.
Darren
[Re: Lil Demon]
#183808
01/05/09 02:38 AM
01/05/09 02:38 AM
Posts: 12,395 Taxes & Virus's R-US, NY
Dragula
Aerospace Components. Plus - I give discounts to Moparts members. Let me know.
Definitely....I have Wilwood's, which are great, light, super simple, 4 piston calipers, two piece hub/rotor, but the Aerospace ones are the next step up. And a 4 piston caliper is so much better at stopping than a production 1 piston caliper, its a wonder we even use them.
[Re: Dragula]
#183809
01/05/09 10:51 AM
01/05/09 10:51 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I have wilwood drum in hat p-brake rears on mine...nice kit, but if they had been available, I would've used the dr. diff 11.7" kit, I think the mustang calipers are a little more all-weather friendly than the wilwoods if you drive year round like I do.
[Re: patrick]
#183810
01/05/09 04:16 PM
01/05/09 04:16 PM
Posts: 6,516 Santa Cruz, California
Lefty
Did you have to install green bearings to run the rear Wilwoods?
