Re: 68 coronet thumb wheel dimmer switch
[Re: cornet684me]
#1837927
05/31/15 12:53 PM
05/31/15 12:53 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
all the lights work, the park lights in the middle position does work, all the lights work now, I was just concern when I found the foil in the fuse box now, The correct fuse is in fuse box also, I guess I need get underthere and run down everything, thanks for the input
I will take the foil out and try to jump wire to bypass the dimmer swtich.
