throttle lever for Hemi cross ram carb
#1836713
05/29/15 03:10 PM
05/29/15 03:10 PM
Posts: 5,140 East Aurora (Buffalo) NY
RoadRunner
Does anyone make the lever that goes on the end of the shaft of a Holley carb used on a cross ram? It looks like a 4160 carb with the choke components removed and a lever added. This is for an aftermarket cross ram installed on a hemi. Or do folks just use the stock throttle lever with a ball stud. I guess I could do that and wrap the fuel line around. Just curious.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: throttle lever for Hemi cross ram carb
[Re: RoadRunner]
#1837084
05/30/15 01:49 AM
05/30/15 01:49 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
All the OEM Hemi carbs. had those lever stock I'm not sure that any of the non Hemi carbs primary shafts are long enough to put one of those brass levers on and still have enough room for the stock linkage to the secondary shafts I would probally try to buy a new pair of the OEM Holley replacement carbs, there still availble I believe
[Re: OUTLAWSSAA]
#1837422
05/30/15 06:19 PM
05/30/15 06:19 PM
RoadRunner
Outlaw, thanks. It looks like if I removed all the choke parts, there would be room to attach the lever arm.
Andy, I had to wipe drool off keyboard.
[Re: WH23H6]
#1837716
05/31/15 02:18 AM
05/31/15 02:18 AM
Cab_Burge
All the OEM Hemi carbs. had those lever stock I'm not sure that any of the non Hemi carbs primary shafts are long enough to put one of those brass levers on and still have enough room for the stock linkage to the secondary shafts I would probally try to buy a new pair of the OEM Holley replacement carbs, there still availble I believe Enjoy the price of those when you buy or race a 426 hemi you know none of the parts for them are cheap for them, correct If you wanted cheap parts you would probally race or own a Ford or Chevy, correct
