Grinding for stroke clearance with 4.5" crank #183698
01/04/09 02:20 PM
01/04/09 02:20 PM
Southington Ct.
turbobitt Offline OP
Southington Ct.
How much grinding is to be expected for a chevy journal 4.5" stroke crank in a world products block ? Just wondering how much I will need to take off the bottom of the cylinders.
Thanks.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Grinding for stroke clearance with 4.5" crank [Re: turbobitt] #183699
01/04/09 04:24 PM
01/04/09 04:24 PM
UK
602heavy Offline
602heavy  Offline
UK
If it helps any i had to clearance around .080 thou for a 4.625 crank on a megablock with chevy journals , was left with around .050 rod bolt to cylinder clearance (K1 rods)
Re: Grinding for stroke clearance with 4.5" crank [Re: 602heavy] #183700
01/04/09 04:28 PM
01/04/09 04:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I did not have to do any grinding for stroke clearance on my World block with a 4.5" stroke Bryant crank. I had to do very minor grinding to the bottom of the bores to clearance for the aluminum rods however.
Re: Grinding for stroke clearance with 4.5" crank [Re: turbobitt] #183701
01/04/09 07:21 PM
01/04/09 07:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
Thanks.
Before grinding on your block mock it up one set of rods and pistons at a time, grind as needed What type of rods, steel or aluminum? Steel rods can live with .030 or larger, aluminum needs more. Follow the rod makers recommendations on how much clearances on the rods and the piston to head clearances A race motor is way better off having a little more clearances than needed on any parts the move than having not quite enough
Re: Grinding for stroke clearance with 4.5" crank [Re: Cab_Burge] #183702
01/04/09 10:07 PM
01/04/09 10:07 PM
Southington Ct.
Southington Ct.
Rods and crank are K1 steel. Just looking for a rough estimate on what to expect.
Re: Grinding for stroke clearance with 4.5" crank [Re: turbobitt] #183703
01/04/09 11:48 PM
01/04/09 11:48 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Im getting ready to find out my self..FYI the Indy Maxx block required ZERO clearances for a 4.5 stroke crank, 2.2 steel rods...Even though a well know shop wanted to charge me several hundred dollars for this work
Re: Grinding for stroke clearance with 4.5" crank [Re: Bob_Coomer] #183704
01/05/09 03:07 AM
01/05/09 03:07 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You should be fine and not require any clearancing at all. But with all things mock it up first.
Re: Grinding for stroke clearance with 4.5" crank [Re: turbobitt] #183705
01/05/09 10:29 AM
01/05/09 10:29 AM
PA
68CudaB1 Offline
68CudaB1  Offline
PA
Our World Alum block w/ 4.625 stroke and Oliver steel rods was fine as far as block clearance.
