Grinding for stroke clearance with 4.5" crank
#183698
01/04/09 02:20 PM
01/04/09 02:20 PM
Posts: 762 Southington Ct.
turbobitt
Southington Ct.
How much grinding is to be expected for a chevy journal 4.5" stroke crank in a world products block ? Just wondering how much I will need to take off the bottom of the cylinders. Thanks.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Grinding for stroke clearance with 4.5" crank
[Re: turbobitt]
#183699
01/04/09 04:24 PM
01/04/09 04:24 PM
Posts: 1,200 UK
602heavy
UK
If it helps any i had to clearance around .080 thou for a 4.625 crank on a megablock with chevy journals , was left with around .050 rod bolt to cylinder clearance (K1 rods)
[Re: 602heavy]
#183700
01/04/09 04:28 PM
01/04/09 04:28 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
I did not have to do any grinding for stroke clearance on my World block with a 4.5" stroke Bryant crank. I had to do very minor grinding to the bottom of the bores to clearance for the aluminum rods however.
[Re: Cab_Burge]
#183702
01/04/09 10:07 PM
01/04/09 10:07 PM
turbobitt
Southington Ct.
Rods and crank are K1 steel. Just looking for a rough estimate on what to expect.
[Re: Bob_Coomer]
#183704
01/05/09 03:07 AM
01/05/09 03:07 AM
Al_Alguire
Las Vegas
You should be fine and not require any clearancing at all. But with all things mock it up first.
