Re: Hard mounting your fuel regulator to the motor? [Re: RMCHRGR] #1836069
05/28/15 04:28 PM
05/28/15 04:28 PM
TX
Kotta390 Offline OP
Kotta390  Offline OP
TX
Originally Posted By RMCHRGR
Huh. Well, maybe call them and see if they might have something that will work for you. I mentioned they do have #8 lines for the Ultra HP carbs, maybe they will be OK.
Like the bracket that wouldn't fit my situation, they probably designed the Magnafuel line kit with the idea that anyone using that regulator is most likely using a Dominator.
True, I am about to take a quick drive to the shop and figure out which style of Holley bowls I have on the carb and one of the techs from AED said depending what it is, will determine if they can go ahead and piece together a kit for me. If they have hard lines that will work then I am golden and can skip the bracket.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836182
05/28/15 08:00 PM
05/28/15 08:00 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Cool. Let us know how it turns out.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Hard mounting your fuel regulator to the motor? [Re: RMCHRGR] #1836193
05/28/15 08:27 PM
05/28/15 08:27 PM
TX
Kotta390 Offline OP
Kotta390  Offline OP
TX
I will as long as they call me back lol.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836278
05/28/15 10:49 PM
05/28/15 10:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I see them mounted on the eng all the time. Mine is on the fenderwell but thats because I was given the lines from the reg to the carb and they were already nicely done at that lenth so it worked best just mounting it on the inner fenderwell but I mounted my friends on his eng as his worked best there. Ron
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836360
05/29/15 12:42 AM
05/29/15 12:42 AM
Originally Posted By Kotta390
I am going to need -8an lines from the regulator to the bowls. I'm running e85 and est. 600hp crank NA. So I think I will probably have to make my own I'm sure. I haven't thought about the bracket hitting the runners of the intake though...? I have an Indy 360-M and that is a pretty big intake for a small block.
I have a 505 C.I. 400 stroker bracket motor that makes 678 HP on E85 using a 1150 Holley Dominator converted to E85 with annular boosters, it has .150 stainless needles and seats in it. I use a #6 AN Teflon lined Stainless steel hose from the Magnafuel 4 port regulator to each carb. bowl, #6 AN I.D. is .375 work scope I was able to enrichen the jeting on the engine dyno test one jet size from what that carb. came with and lost power by being to fat with that set up. I ended up jetting it down 3 jet sizes to make max HP and torque, that was on a DTS engine dyno in Klamamth Falls Oregon which is at 4300 Ft. above sea level shruggy I have not tried jetting it up enough to slow the car down in MPH at a 1/4 mile track yet, we race at Madras which is 2500 Ft altitude and it is a 1/8 mile track shruggyIHTHs up
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836388
05/29/15 01:19 AM
05/29/15 01:19 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I was wondering when someone was going to point that out. Even with a "sewer pipe" .150 E85 needle/seat, that opening is far more of a restriction than a few inches of smooth-bore .375 hose. Even less of a factor for gasoline carbs.
I like to use #6 Teflon also because it's impervious to any fuel, and also significantly smaller in diameter than the braided steel rubber hose. Doesn't cost that much more either up
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836472
05/29/15 05:46 AM
05/29/15 05:46 AM
TX
Kotta390 Offline OP
Kotta390  Offline OP
TX
I talked to Patrick at Pro Systems yesterday and I could have sworn he said use #8, but he assured me that #6 would be fine. Sorry for the confusion
