My 70 'Cuda
#183622
01/04/09 02:09 PM
01/04/09 02:09 PM
Posts: 82 Austria
3eighty3
Austria
Hello everyone, Here's my 1970 Cuda. The project is going into its second year and after watching a few episodes of overhaulin' it's hard to imagine ever to be able to strech that out for so long... Anyway, this is how I found the 'Cuda just over a year ago: In the meantime, I took the car apart and - surprise - it was a lot rustier than I thought... A lot of parts had to be replaced, especially in the rear of the car. The bodywork should be done by march, after that it's off for paint and the nice work of putting everything back together. A few things will be ready and waiting by then... ...others are still awaiting being worked over. thomas _________________________________________________ Cuda blog
Re: My 70 'Cuda
[Re: HemiChallenger]
#183624
01/05/09 06:20 AM
01/05/09 06:20 AM
Posts: 82 Austria
3eighty3
Austria
Hi Steve, Thanks...it's a real Cuda, came with the high performance 383, 4bbl Holley and Automatic Trans. Unfortunately it was quite rusty, on the other hand, all the original parts were there, pretty well unmolesterd with. It had drums on all corners but I will swap the front brakes for dics. The car was originally BL1 sand pebble beige, but I haven't made a decision on the color yet... might go with the original since they seem to be quite rare and it would go with the gator top I fell for thomas _____________________________________ cuda blog
Re: My 70 'Cuda
[Re: 3eighty3]
#183625
01/05/09 04:20 PM
01/05/09 04:20 PM
Posts: 82 Austria
3eighty3
Austria
More news from the welding front. The rear is pretty well finished so the front is being given some attention. The passenger side lower corner of the windshield is fixed, looked pretty ragged there. In front of the door a piece had to be replaced completely, even stronger than the original, the circular stamping was fabricated into the piece as well! Since the quarters are on I have started on the classic graphics with the engine call out thomas _______________________________________________ cuda blog
Re: My 70 'Cuda
[Re: 70shaker6pk]
#183627
01/07/09 02:34 PM
01/07/09 02:34 PM
Posts: 82 Austria
3eighty3
Austria
keep those pic's coming, thanks
No new pics at the moment so I'll show you some of the older ones. Here's the Cuda just prior to blasting:
Most of the damage was in the rear of the car, trunkfloor, inner fenders the usual suspects.
The floor inside the car was astonishingly sound, only a few small pieces to replace here:
Some of the Structure behind the driverside C-pillar had to be replaced, it had gotten a little soft
Here's the new driver side rear fender in place:
Luckily the inside fender halves had become available just before I needed them...
thomas
cuda blog
Re: My 70 'Cuda
#183629
01/16/09 11:55 AM
01/16/09 11:55 AM
Posts: 82 Austria
3eighty3
Austria
Got the radiator back from being redone at a specialty shop. I had the original radiator redone with more cores for better cooling. Turned out I could have bought two reproduction radiators for the money and on top of that they didn't even paint it very well... thomas ______________________________________________ cuda blog
Re: My 70 'Cuda
[Re: 3eighty3]
#183630
01/29/09 04:04 AM
01/29/09 04:04 AM
Posts: 82 Austria
3eighty3
Austria
Got started on the engine buildup. Here's the preliminary mockup of the right side engine valvetrain. It's assembled without gaskets just to see if everything will fit properly. Actually, there was an issue with the pushrods, the ones I ordered were too long, obviously made for engines without hydraulic lifters. Even though I didn't think so, the valve covers will actually fit over the rocker arms...got lucky there! thomas ______________________________________________ cuda blog
Re: My 70 'Cuda
[Re: 69Cuda340S]
#183632
02/02/09 12:01 PM
02/02/09 12:01 PM
Posts: 82 Austria
3eighty3
Austria
Nothing sexy but a little more progress: I started on some interior trim, here the metal pieces that go around the rear window. Since the car rusted from the inside out these parts did show serious signs of decay: Since the parts have a surfacestructure to them - obviously they are supposed to look a little like leather - I refrained from trying to sand them by myself and had them mediablasted. After that I sprayed some primer on both sides of the trim, to keep them from rusting again untill they get their final color. Most of the parts turned out really nice, unfortunately the one piece that goes under the rear window was rusted beyond repair and now has many small holes.. I primerd it up anyway but I will be looking for a replacement. thomas _______________________________________________ cuda blog
Re: My 70 'Cuda
[Re: moparmojo]
#183635
02/16/09 07:58 AM
02/16/09 07:58 AM
Posts: 82 Austria
3eighty3
Austria
The plates for the LCAs were fabricated from scratch as they are simple parts, occasionallly you can also get them on ebay... Firmfeel sells finished reinforced control arms: firmfeel The inner fender braces can be obtained at xv-motorsports: xv-motorsports In my case we reinforced both ends of the bar with a flat piece of metal, the one above the shockperch hat to be fabricated to fit inside the brace. Without that the bar would only be welded to a relatively thin piece of metal, and wouldn't fulfill its full potential. thomas _____________________________________________ cuda blog
Re: My 70 'Cuda
[Re: 3eighty3]
#183636
02/22/09 05:02 PM
02/22/09 05:02 PM
Posts: 82 Austria
3eighty3
Austria
Got the front suspension pretty well done, waiting to be bolted to the body: The steering box is a quick ratio from firmfeel, I will also add tubular a-arms to replace the originals. thomas ______________________________________________ cuda blog
Re: My 70 'Cuda
[Re: Kam*Kuda]
#183640
02/23/09 06:58 PM
02/23/09 06:58 PM
Posts: 82 Austria
3eighty3
Austria
I will look if I have one of these around.
Thank's that would be nice of you. It's the short one, that fits the rear window.
cuda blog
Re: My 70 'Cuda
[Re: 3eighty3]
#183641
03/04/09 12:41 PM
03/04/09 12:41 PM
Posts: 82 Austria
3eighty3
Austria
The body is about finished at the bodyshop. All the holes filled, weld seams done with body solder: There's a little more to do on the doors and the fender, then it's off for paint preperation.... thomas ______________________________________________ cuda blog
