Page 4 of 5 1 2 3 4 5
Re: Another Edelbrock Victor Saga [Re: BradH] #1835999
05/28/15 02:32 PM
05/28/15 02:32 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Originally Posted By BradH
Originally Posted By crackedback
Yep, all the same fulcrum lengths...
At least you could give AndyF credit for that photo...
Yes, AndyF does get credit for the photo, however, the premise of that photo is incorrect. The fulcrum length has nothing to do with proper geometry as it relates to efficient, stable, valvetrain operation. For me, all it means is "How far am I going to have to offset the shaft once I have it at the correct height?".
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Another Edelbrock Victor Saga [Re: B3RE] #1836003
05/28/15 02:38 PM
05/28/15 02:38 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Have you ever found a head/rocker/valve height that was actually correct? other then maybe stock?
Makes me wonder why they even put them on, or how they decide where to put the stands.
Re: Another Edelbrock Victor Saga [Re: Quicktree] #1836007
05/28/15 02:51 PM
05/28/15 02:51 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Originally Posted By Quicktree
I know what he does and have no problem with it. the problem is when he first came on here there was some claim to adding horse power by a simple correction. and my offer still stands just like the one with our newly found carb guru. you make claim back it up. I will still wager that he can correct mine from where they are now and you would see little gain if any. I set mine up just like have done for nearly 40 years and I get more than my fair share of passes. I know the geometry is off it's always been off. long before correction part were available.
If your current rocker arm set up has a very wide sweep the mechanical action input on the adjuster side is not making efficient use on the output side and you have loss of lift at the valve. The max lift may not be impacted much but the all important low and mid lift (where the valve spends the majority of the time) will have less valve lift, slower rate of lift, and adversely flow potential. Think of it like buying a fast ramp roller cam only to and find out you are missing out on performance potential because the rocker is sweeping out some instead of opening the valve.
Will the correction make power?
If your geometry is off (wide sweep) in theory yes it will make more power.
Can an amount be guaranteed?
No, way too many variables. However, your valvetrain will be more stable if corrected.
Theres got to be a reason why when Jesels are installed the installed valve stem height is relative to where the subplates mount on the head.
Re: Another Edelbrock Victor Saga [Re: B3RE] #1836030
05/28/15 03:21 PM
05/28/15 03:21 PM
dogdays Offline
dogdays  Offline
That's a lot of work. Over or under $1000? I'm betting over.
R.
Re: Another Edelbrock Victor Saga [Re: CTD5.9] #1836037
05/28/15 03:26 PM
05/28/15 03:26 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Let's put it this way. With a stock head and stock length valve, and Harland Sharp rockers, you would have to have over .900" lift to get the correct action at the valve. You can't get that with a stock length valve, and a longer valve would mean you would need more lift, and a longer valve, and more lift, and........... You can't get there!
I don't have a fast track into the mind of the cylinder head engineers, but my theory is, 'The consumer doesn't want to buy something that requires additional work, so we put stands on the head that will accept shaft style rockers. However, it can't be at the right place for everyone, so we will put it at the factory location. That way, if anyone complains, we can say we used the factory engineering'. That's my best guess.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: dogdays] #1836043
05/28/15 03:34 PM
05/28/15 03:34 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
R.
For my time, it should have been over, but I cut the guy some slack. Only because I spent three days trying to figure out the best way to do it. Every time I would try something it would cause another issue, it seemed. He was out about $800. I figure I made about $3/hr on that one. I guess the steak and seafood dinner will have to wait. lol
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1836104
05/28/15 05:41 PM
05/28/15 05:41 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Nice work on the stands!! My Victor/Sharp combo is getting by OK but only .674 lift and 1.900 installed spring. Those are the first Victors I've seen with new stands installed. The stands keyed to head plus the extra screws look to be a solid setup thumbs
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Another Edelbrock Victor Saga [Re: BradH] #1836132
05/28/15 06:55 PM
05/28/15 06:55 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Hey, Sleepy! Where were the other six Dwarfs? grin
wasn't sleeping, it was dark in there and some knucklehead was taking pictures. but I was tired as hell after walking about 50 miles in that place. I did see Elvis running around laugh2
Re: Another Edelbrock Victor Saga [Re: MoParFish] #1836181
05/28/15 08:00 PM
05/28/15 08:00 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Thanks! I'm looking forward to seeing the car make a few passes, since he is fairly local. Cecil County is his home track.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1836240
05/28/15 09:50 PM
05/28/15 09:50 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Originally Posted By B3RE
Originally Posted By 451Mopar
At least that is the newer castings with the extra material above the intake ports. I ended up using PAC 1326 valve springs with thinner valve spring locators (I think 0.030") that PAC milled for us, plus the +0.100" PAC Ti retainers, standard locks, and lash caps. Using the max wedge rocker shaft blocks we just set the shaft height where it looked OK, but it would have been nice to have the offset like shown here.
I have some photos, but need to figure how to post them?
I wish they would have had more material above the ports. It would have made things a little easier than trying to cram everything onto that little stand boss.
I'd love to see your pics. Below the post window, click "File Manager"-then "Browse"-then "Add File"-then "Done Adding Files". That will load files from your computer. Not sure about from a phone.
Re: Another Edelbrock Victor Saga [Re: 451Mopar] #1836241
05/28/15 09:51 PM
05/28/15 09:51 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
A few more
Re: Another Edelbrock Victor Saga [Re: B3RE] #1836285
05/28/15 10:56 PM
05/28/15 10:56 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Any idea what would be a good cam lift and install height to target to avoid all the extra work you had to do if building a 512 with the victor max port?
Re: Another Edelbrock Victor Saga [Re: mopar dave] #1836295
05/28/15 11:08 PM
05/28/15 11:08 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1516685/1.html
Re: Another Edelbrock Victor Saga [Re: B3RE] #1836333
05/29/15 12:00 AM
05/29/15 12:00 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Why on earth would anyone use these heads? How could a major head manufacture build a head with so many dimensions incorrect? Whoever signed off on these heads should be unemployed. Power wise I've yet to see one much better than an -1. Nothing fits. You have to ask yourself why? I've seen plenty of complaints about Indy as a company, but the castings are used by the thousands without failure. In fact I think I've seen more failures on the few Victors that are being run. Nice work on the fix. I just can't see going to all that trouble for little or no gain in performance.
Doug
Re: Another Edelbrock Victor Saga [Re: B3RE] #1836363
05/29/15 12:49 AM
05/29/15 12:49 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Because Ebrock makes heads for the masses and unfortunately that mass is a bunch of cheap azz Mopar guys! It would have been anarchy to spit a head out with no stands and let the builder design as needed..... but you have to realize too that this project appears to be using an Ebrock Victor above and beyond its target audience...... and that's cool! Great post!
Re: Another Edelbrock Victor Saga [Re: B3RE] #1836396
05/29/15 01:25 AM
05/29/15 01:25 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
How did you know I got my Victors on a Black Friday, roll back, double coupon, blue light special haha
Re: Another Edelbrock Victor Saga [Re: MoParFish] #1836567
05/29/15 11:57 AM
05/29/15 11:57 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
mopar dave, Ok, first, the only reason those heads required all that work is because of the reduced shaft diameter and fulcrum length of the T&D rockers. There was no way to offset the shafts enough without risking failure of the shafts. The correct lift would be far beyond the capability of the installed height to get the proper sweep action with the shafts just bolted on. You could probably do what Jeremiah did with his Victors, and have everything correct.
MoParFish, I can see from your photos that the roller starts inboard and stops outboard at full lift. The roller should stop at the same place it started if the geometry is correct (sweep out-sweep in). The lash caps are making that condition worse, but they keep the roller from rolling off the valve when the geometry is off. With .674 lift, your sweep should be roughly .038" when correct. No need for the caps. You've got a nice motor there. I just wish the valvetrain was optimized.
With a BB Harland Sharp rocker, and 1.00" lift, the sweep across the valve should be .084". How many guys out there are getting that much sweep, or more, with .600" or less lift? I've seen a lot of them myself, so I know there are a lot more.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: dvw] #1836575
05/29/15 12:04 PM
05/29/15 12:04 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Doug
The Indy heads are no different. They need the rocker shafts relocated, just like any other head with cast in stands. I've done enough to know.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1836587
05/29/15 12:15 PM
05/29/15 12:15 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Got some feedback from the engine builder, and he wanted to pass along some info that answers a few of the questions I couldn't answer. From the email:
"Good morning Mike.
I seen the write up on Moparts about Jeremys heads. Let the guys know that 3/8 pushrods fit with plenty of room. I think a 7/16 would go with no additional work. Also I seen some one asked about valve length and they were .150 longer the what the heads would have had from Edelbrock."
I also got a call from one of the well known (he advertises here I believe) Mopar engine builders using my kits. He did a before and after test, and picked up 500 rpm with 130# less spring pressure. He said the motor made great power as well. He's pretty happy, because he is always looking for ways to make more power. He must be, he ordered four more kits, and said he has more coming.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1837069
05/30/15 01:22 AM
05/30/15 01:22 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Doug
Mine have T&D paired which I did move. However Most are run as is. The difference is that the average person can bolt and Indy together and run it. The rockers and push rods don't hit anything. Perfect, no, but usable. I have yet to see a Victor that everything bolts on. Rockers hit the retainers, pushrods hit the heads, the rocker shaft bolts pull the threads, valve covers don't fit, spring height to short. Why use them?
Doug
