Hard mounting your fuel regulator to the motor? #1835404
05/27/15 04:52 PM
05/27/15 04:52 PM
TX
Kotta390 Offline OP
Kotta390  Offline OP
TX
Hey guys, new here just not new to Mopars smile. I decided to join this community because it was long overdue. I have a 1989 Dakota that I am building a street truck out of by using my previous race motor that I had in a Gen 3 99 Dakota. Adobedude knows who I am. Anyways I had a question.
Why is it bad to hard mount your fuel regulator to the motor? I can understand vibrations may screw with the reading of your fuel pressure gauge but in the past I have hard mounted mine and never had any issues?
Any advice or thoughts? My new setup will be the same but going E85 instead of race fuel. I will also be running polyurethane mounts instead of solid mounts.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1835406
05/27/15 04:56 PM
05/27/15 04:56 PM
an8sec70cuda Offline
I've never heard of it being a bad thing. shruggy LOTS of people run them that way. Always had mine mounted to the motor and never had any issues.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1835424
05/27/15 05:46 PM
05/27/15 05:46 PM
Andrewh Offline
Andrewh  Offline
fords mount it to the fuel rail from the factory.
no gauge, so not an issue.
that would be the only reason.if you have a gauge mounted to it, I probably wouldn't.
but the regulator itself should be fine.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1835425
05/27/15 05:50 PM
05/27/15 05:50 PM
AndyF Offline
AndyF  Offline
Lots of people do it that way but the pros usually hang the regulator from the fuel lines in order to reduce vibration. They do a lot of stuff to keep the fuel from getting frothy with air bubbles.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1835462
05/27/15 06:37 PM
05/27/15 06:37 PM
TX
Kotta390 Offline OP
Kotta390  Offline OP
TX
Yeah well I feel like with polyurethane motor mounts, a rubber isolator between the regulator and the mount and I feel like I shouldn't have any problems. I will have a gauge attached to it and it will be liquid filled like my last one and my last gauge never had issues with bouncing all over the place and I never noticed any airration of the fuel. I am just trying to cover my grounds before I do something stupid. It's not going to be a mild motor so....that's what I'm asking lol.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1835594
05/27/15 10:31 PM
05/27/15 10:31 PM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
This is what I have.
There is a kit from AED you can get with pre-bent stainless lines and the aluminum fittings. I made the one in the pic myself though.
AED fuel lines
They also have a bracket that you mount to the carb base and the regulator hangs off of it.
AED Bracket
I couldn't use it though because the bottom of the regulator was hitting the intake runner. I will sell it to you if you want, PM me.
The lines hold it tight enough without the bracket. I have run it like that on the street and at the track a handful of times and it's never leaked once. I've had it apart a zillion times too.
'71 Duster
'17 Ram 1500
Re: Hard mounting your fuel regulator to the motor? [Re: AndyF] #1835632
05/27/15 11:24 PM
05/27/15 11:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's right, in high horsepower engines can create some serious vibrations and can lift the diaphragm off it's seat more or less during extreme vibration in regulators and in check/poppet valves in fuel injection. . Should always try to provide some vibration isolation.
Frothy air bubbles... work Definitely don't want them in front of the fuel pump, after up by the engine not as much of a concern at that point.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1835639
05/27/15 11:35 PM
05/27/15 11:35 PM
I've mounted several different brands and sizes of fuel regs. on of the front motor plate or elephant ears awith no real consequences that I'm aware of shruggy I have had them hooked into a hard aluminum fuel line laying on the intake manifold under the carb. also tsk, I don't do that anymore upI think Monte Smith put on one of his comments to mount the regulator in front of the carb. so the high pressure fuel is fed into the regulator in front of the needles and seats and then reduce in pressure back to the carb. up
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1835652
05/27/15 11:48 PM
05/27/15 11:48 PM
TX
Kotta390 Offline OP
Kotta390  Offline OP
TX
I am going to need -8an lines from the regulator to the bowls. I'm running e85 and est. 600hp crank NA. So I think I will probably have to make my own I'm sure. I haven't thought about the bracket hitting the runners of the intake though...? I have an Indy 360-M and that is a pretty big intake for a small block.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1835699
05/28/15 12:35 AM
05/28/15 12:35 AM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
If you are referring to what I was saying about my setup - it wasn't the bracket itself hitting the intake. (Victor W2) The problem is that the bracket puts the regulator right over the runner and there was no room for the fuel line. I used a 90* adapter for the bottom feed. My fuel line comes off a mechanical pump in front though so if you have an electric you have some more options. It would probably be easier with the feed line coming up the back of the motor, you could run it under the intake.
I stumbled on the way I have it set up, just wanted to see if it would work and it did since the bracket was a no-go. I called AED and they said it was fine to run it without the bracket.
If the bracket just extended a little farther back it would have been fine. Only thing I could think of was that they designed it with something other than a SBM with a single plane.
You could put it in front where there is no runner interference but then the lines become tough to deal with since the regulator is in front of the bowl.
There are other brackets out there. Allstar makes ones for 4150 and Dominator.
Allstar bracket.
Or make your own bracket if it's how you want to solve the issue, it's not that hard. The AED bracket should give you a good idea of what to do. Just won't be fancy anodized billet.
'71 Duster
'17 Ram 1500
Re: Hard mounting your fuel regulator to the motor? [Re: RMCHRGR] #1835750
05/28/15 01:44 AM
05/28/15 01:44 AM
TX
Kotta390 Offline OP
Kotta390  Offline OP
TX
Allstar bracket.
Yeah that makes more sense now. I was going to use the bracket made by Magnafuel since I'm going a full magnafuel setup and the only thing they don't offer is the fuel lines coming off the regulator to the bowls. I like the idea of running the fuel line from the back of the motor and under the intake, which God knows there is plenty of room lol! I will look into it some more and figure out how I want to go about it. I just don't have a tubing bender and cutting and fitting the stainless braided lines kinda suck haha. Thanks for the info.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1835751
05/28/15 01:46 AM
05/28/15 01:46 AM
TX
Kotta390 Offline OP
Kotta390  Offline OP
TX
Btw I have been on my phone for most of this and I am still trying to figure out the website some. Can anyone help me out to where I can find the for sale section that has engine parts, fuel components and misc items that relate to go fast parts?
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836016
05/28/15 03:06 PM
05/28/15 03:06 PM
dogdays Offline
dogdays  Offline
Go to the Forum list. Scroll down. At the bottom of the page are the listings for the Online Swap Meet.
R.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836020
05/28/15 03:08 PM
05/28/15 03:08 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
There is no problem letting them hang by the lines themselves. We have been doing it for years. I can tell you the fuel pressure stays more stable than hard mounting, we have tried both and log all of it on a racepak. Here are a few of mine.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836022
05/28/15 03:10 PM
05/28/15 03:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
AS for the question on the Forum, if you go to Moparts forums and scroll down you will find for sale sections on just about everything. There is a raceparts section as well as engine and body specific areas.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836025
05/28/15 03:16 PM
05/28/15 03:16 PM
TX
Kotta390 Offline OP
Kotta390  Offline OP
TX
Yeah I might end up not hard mounting it, IDK yet. Really it's one less thing to worry about I suppose. Coming from your pictures, the first and last picture looks almost like the 90* fitting is rubbing the base of the intake or is it just the angle? I also don't want to go down bumps in the road and then cause the fitting or the regulator to chafe against the intake, of course now that I think about it if I have the fuel lines shorter it will raise the regulator too.
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836046
05/28/15 03:36 PM
05/28/15 03:36 PM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
What carb? 4150 or Dominator? Hate to keep pushing their products but AED has a stainless line kit for the Magnafuel regulator with a Dominator. They do make -8 lines for the Ultra HP carbs.
Line kit
If you're not able to fab the lines by yourself, then just get what you need.
'71 Duster
'17 Ram 1500
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836054
05/28/15 03:52 PM
05/28/15 03:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Nothing it touching anything.
Re: Hard mounting your fuel regulator to the motor? [Re: RMCHRGR] #1836056
05/28/15 03:56 PM
05/28/15 03:56 PM
TX
Kotta390 Offline OP
Kotta390  Offline OP
TX
Line kit
Its a Pro Systems 950hp 4150 carb.
Sucks that is the kit I would probably need but its for a 4500 series frown
Re: Hard mounting your fuel regulator to the motor? [Re: Kotta390] #1836062
05/28/15 04:11 PM
05/28/15 04:11 PM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
Huh. Well, maybe call them and see if they might have something that will work for you. I mentioned they do have #8 lines for the Ultra HP carbs, maybe they will be OK.
Like the bracket that wouldn't fit my situation, they probably designed the Magnafuel line kit with the idea that anyone using that regulator is most likely using a Dominator.
'71 Duster
'17 Ram 1500
