Do these bearings look OK? #1835654
05/27/15 11:50 PM
05/27/15 11:50 PM
Cumberland, MD
Moparguy383 Offline OP
Cumberland, MD
Hi,
These are brand new rod and main bearings, cut the plastic off of the boxes myself and they don't look right to me. The mains are Speed Pro part #119-M and the rods are Clevite #CB-743-HN. They almost look burnt, I don't know how else to describe it. What do you think? TIA
Re: Do these bearings look OK? [Re: Moparguy383] #1835659
05/27/15 11:52 PM
05/27/15 11:52 PM
Cumberland, MD
Cumberland, MD
more
Re: Do these bearings look OK? [Re: Moparguy383] #1835664
05/27/15 11:54 PM
05/27/15 11:54 PM
Cumberland, MD
Cumberland, MD
more
Re: Do these bearings look OK? [Re: Moparguy383] #1835665
05/27/15 11:56 PM
05/27/15 11:56 PM
Cumberland, MD
Cumberland, MD
more
Re: Do these bearings look OK? [Re: Moparguy383] #1835669
05/27/15 11:59 PM
05/27/15 11:59 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Yes, Some performance bearing sets don't have the final flash coating of tin. They don't look pretty, But work just fine.
The only Carbs I care about are under the hood!
Re: Do these bearings look OK? [Re: Moparguy383] #1835754
05/28/15 01:51 AM
05/28/15 01:51 AM
WA
JD Dart Offline
JD Dart  Offline
WA
I get those bearings 119 all the time and have never seen a set like that send them back. Maybe China will do a better job next time
Re: Do these bearings look OK? [Re: JD Dart] #1835910
05/28/15 12:28 PM
05/28/15 12:28 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I have seen that before. Our last set looked like that. They are running fine in our 540. I wouldn't worry.
Re: Do these bearings look OK? [Re: JD Dart] #1835939
05/28/15 01:07 PM
05/28/15 01:07 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By JD Dart
I get those bearings 119 all the time and have never seen a set like that...
Me, either. down
Mine are never "pretty", but they don't look like THAT, either.
Re: Do these bearings look OK? [Re: BradH] #1836059
05/28/15 04:02 PM
05/28/15 04:02 PM
dogdays Offline
dogdays  Offline
Clevite says,
H Series - •Best to start with when unsure which bearing to choose
•Medium level of eccentricity and high crush
•Enlarged chamfers for greater crankshaft fillet clearance
•Made without flash plating for better seating
•Use with crankshafts that have oversized fillets
•Use with engines that run mid-high RPM range
•Contact patterns should ideally cover 2/3 to 3/4 of the bearing surface
Competition Series bearings have an unusual appearance. They are not the normal white/gray color because the flash tin plate process has been eliminated. Flash tin plating makes a bearing look pretty, but this tin may migrate across the steel back under running conditions and cause undesirable high spots on the I.D. of the bearing. These high spots can intrude into the oil clearance and become concentrated load areas susceptible to premature fatigue. The tin may also migrate into the lining material, reducing it's strength. As an added benefit, the elimination of the flash tin plate allows greater dimensional accuracy. If your engine will be used in competition, or for high performance street use, we highly recommend that you select the Competition Series Rod Sets and Main Sets Super Duty Alloy (CH) Our unique high performance H-14 Super Duty Trimetal Copper-Lead lining material is bonded to an extra-high strength steel backing for unparalleled bearing durability in high stress racing engines. This material will outperform competitors products by a wide margin in virtually any application from street performance to all out racing. We highly recommend this material for any performance use. (Except for blown race applications, which use our Babbitt bearings)
H-14 -The Super Duty Bearing (when strong is better than pretty!)
The unique H-14 lining material found in our Competition Series bearings was specifically designed for high performance, and has a far greater load capacity than any other material We bond this lining to an extra high strength steel backing, creating the best performance bearing in the industry. These materials are Federal-Mogul exclusives, and are not available from any other source.
That's what the main bearings are.
I have new high performance bearings that look like those.
R.
Re: Do these bearings look OK? [Re: dogdays] #1836184
05/28/15 08:05 PM
05/28/15 08:05 PM
Cumberland, MD
Cumberland, MD
Thanks for input guys.
Re: Do these bearings look OK? [Re: dogdays] #1836394
05/29/15 01:23 AM
05/29/15 01:23 AM
Originally Posted By dogdays
Clevite says,
R.
I have several sets of new Clevite mains that look like that also, they measured good on the clearnances with a dial bore gauge so I used them, crank turns fine with no rods or pistons attached so in my book there golden up
Re: Do these bearings look OK? [Re: Moparguy383] #1836415
05/29/15 01:56 AM
05/29/15 01:56 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I just went thru the same thing, I open my Clevite rod and main bearings look similar to yours. Called Clevite and the tech person said this is normal and it was from the rinse process, but is perfectly fine. My rod bearings #cb-743 hn had scratches on 3 sets all in the same place on all of the upper shells, Waiting for replacements to assemble my motor. I have used Clevite bearings before and never recalled them looking this bad! Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Do these bearings look OK? [Re: Moparguy383] #1836561
05/29/15 11:51 AM
05/29/15 11:51 AM
an8sec70cuda Offline
Same bearings I use in my hemi. That's normal from what I've seen and used.
CHIP
'06 GMC 2500HD LBZ Duramax
