Re: Any experience with Mahle pistons?
[Re: AndyF]
#1835275
05/27/15 02:39 PM
05/27/15 02:39 PM
Posts: 369 Indy
496 A-body
Indy
I see that Mahle now has a few Mopar pistons including some that work for stroker engines. One of the choices has a CH of 1.475 so it can work with a 7.100 rod in a RB block or a 6.535 rod in a B block. 1.5/1.5/3.0 mm ring stack. Catalog says 8cc valve relief which seems generous but doesn't give any dimensions. I am curious about the valve relief too, 8cc seems very large and makes me wonder if that is effective volume due to not being zero deck since they state compression ratios at different chamber sizes yet they do not state a deck height. Pistons are very light and the price is great considering that they come with rings.
[Re: AndyF]
#1835294
05/27/15 02:58 PM
05/27/15 02:58 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I have not used any of their Mopar pistons, but have used small block Chev and had some custom Cummins pistons made and all was good with them. Very informative and easy to talk to tech...Eric Guirillo(sp?)
If you like drag racing, support your local track.
[Re: AndyF]
#1835399
05/27/15 04:46 PM
05/27/15 04:46 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have ran a couple, very light weight, anti friction coating, rings included, hard anodized all over, very nice piston for the money. The only complaint I had with one set in a SB stroker is the dished piston has a huge dish (28CC I think it was) and very little quench area, I like a large quench area and a little higher compression than most guys will run. That 416 made an awesome tow truck engine though.
[Re: AndyF]
#1835438
05/27/15 06:09 PM
05/27/15 06:09 PM
HotRodDave
Kalispell Mt.
I think they have 2 not counting oversizes, flat top and huge dish for 4 inch with stock pin size. They make a flat top 360 stroke piston and a 340 stroke flat top.
[Re: AndyF]
#1835951
05/28/15 01:25 PM
05/28/15 01:25 PM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
Mahle in one of the largest (if not the larget) OEM piston manufacturers in Europe, so the tooling and maintenance is always world class so for the price point you're buying top quality ISO standard components.
The downside is because of their target market will naturally lack customization and as such you will lack choices in terms of Valve notches/Compression heights, etc.
They have a relatively new manufacturing plant right here in North Carolina so there is some element of supporting the local economy for me too.
[Re: Streetwize]
#1836254
05/28/15 10:14 PM
05/28/15 10:14 PM
crabman173
crabman173
In Kits ordered from Eagle with Mahles for stroker bb mopars I have had two with the wrong oil ring expander--called Mahle the first time--they said nip the expander and keep rolling--I have done it before so no big deal did it and rolled on--they had less tension than I would have liked but.... Second time I got weird oil expanders, I had been hearing from other builders about this so called Mahle again--tech guy said I was NUTS to nip those expanders and was not an engine builder etc--OK...( he may be right--who knows)I just ordered some CORRECT rings from Total Seal and solved the problem--that-- and Eagles kits are FT and do not offer the correct dish volume for many street CR builds so I am done with the Mahle--for now-- Everyone is going crazy for skinny rings--I know they make a little more HP but really--the 3.0mm oil ring is very easy to screw up and for a once in a while home builder I would say very easy to ruin the oil rings on install and for what? a few extra HP on a big street stroker that is if anything over muscled to start with for average guy--give me plain old 1/16th foolproof anytime--all this chasing a few extra HP at every single turn is driven by internet chats and chatter--anyone in the world would / should be pretty happy with any sort of BB Mopar stroker with decent heads--as a street ride. They all drive like the Zamboni at the skate rink anyway -- I don't even pick up any magazines anymore--if you don't have over 800HP they think you are not really engaged in the hobby--I mean 1200HP articles and turboed this and that is all they write about--bet half the guys in the world would near have a stroke if they rode in a real 600 HP street car. I still think a real 500 HP Mopar is a beautiful unit on the street and stays well within the limits of a real Mopar car--
