Page 1 of 5 1 2 3 4 5
Another Edelbrock Victor Saga #1835134
05/27/15 10:16 AM
05/27/15 10:16 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Had a customer bring some Victors that needed a little valvetrain work. His engine builder wasn't getting anywhere by talking to the rocker manufacturer, and he remembered talking to me at Carlisle about this stuff. Easy fix, right? Uhhhh, NOT!
A picture is worth a thousand words, they say. Here are several.
Looks pretty standard, right?
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835137
05/27/15 10:22 AM
05/27/15 10:22 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Uh Oh!
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835140
05/27/15 10:33 AM
05/27/15 10:33 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Ok, I'll just make up a kit and get it corrected, right? Nope, the engine builder would rather have stands made. Additionally, T&D uses a .750" shaft, so with the .120" offset needed to get the roller where it needs to be, elongating the holes in the shaft would weaken it too much. This is going to suck!
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835144
05/27/15 10:45 AM
05/27/15 10:45 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Alright, throw it in the mill and start cutting off the stands, fill the bolt holes, weld, re-drill and tap, heli-coil, cut a keyway, and add additional support screws for the three center stands. Then grab some 6061T6-511 bar and start making new stands.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835145
05/27/15 10:52 AM
05/27/15 10:52 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Ok, get it all together and, CRAP! The roller is too far inboard. It would run, but I don't like it. Neither does the engine builder. Time to make another set of stands.
phone uploads 005.jpg (1265 downloads)
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835148
05/27/15 10:56 AM
05/27/15 10:56 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
A better pic of the roller placement.
phone uploads 004.jpg (1415 downloads)
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835149
05/27/15 10:56 AM
05/27/15 10:56 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Is the 1.7 ratio a contributing factor??
Or T&D's design?
Joe
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835151
05/27/15 10:59 AM
05/27/15 10:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
So on this set of heads how far did you move
the shaft(in,out, up,down)
wave
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835153
05/27/15 11:04 AM
05/27/15 11:04 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
The sweep across the valve was right where it was supposed to be for a .718" net lift roller cam. The offset just needed an adjustment.
phone uploads 013.jpg (1214 downloads)
phone uploads 014.jpg (1236 downloads)
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: jlatessa] #1835155
05/27/15 11:09 AM
05/27/15 11:09 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
It has nothing to do with the rocker design or ratio. It is the location of the fulcrum centerline, aka. shaft centerline, that determines the proper geometry. Every engine will need a specific location for the shaft for its combination. The factory location will only be correct for a factory spec engine. Change anything, and it will need to change also.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: MR_P_BODY] #1835156
05/27/15 11:10 AM
05/27/15 11:10 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Final numbers were .290" up, and .085" offset.
Good to see you back again, Mike! I hope you're doing well!
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835163
05/27/15 11:17 AM
05/27/15 11:17 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Here is a completed head. There is plenty of clearance for the spring and retainer. Even though it looks close from a profile shot, you can't see the relief in the rocker that would allow another .100" in spring diameter.
phone uploads 029.jpg (1169 downloads)
phone uploads 027.jpg (1155 downloads)
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835165
05/27/15 11:21 AM
05/27/15 11:21 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
More
phone uploads 030.jpg (1087 downloads)
phone uploads 025.jpg (1117 downloads)
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835168
05/27/15 11:23 AM
05/27/15 11:23 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Not my Victors, but I'm still interested in this thread.
Is that combination going to need valve cover spacers now?
Where did you get studs that long?
Re: Another Edelbrock Victor Saga [Re: BradH] #1835174
05/27/15 11:32 AM
05/27/15 11:32 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
He has pretty tall fabbed valve covers, so I doubt it. The real problem is side clearance. Edelbrock raised the rail on these heads, but they went straight up instead of on the incline of the valve, and that crowds the tail end of the rocker. You definitely couldn't use a cast cover.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835186
05/27/15 11:55 AM
05/27/15 11:55 AM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Good luck getting a spring pressure measuring tool in there!
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835196
05/27/15 12:15 PM
05/27/15 12:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my SB stuff I have to use reverse lip valve
covers and still have to notch the lip of the
cover and the gasket to clear
wave
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835220
05/27/15 01:06 PM
05/27/15 01:06 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
B3RE,
Love your threads and you did some work for a buddy in Tucson. My question would be wouldn't a shorter valve help the situation out? I'm sure the valve lift has something to do with the length of valve that can be used? Just curious. thx matt
[img] [/img]
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835261
05/27/15 02:16 PM
05/27/15 02:16 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Very nice work Mike!
Seems like I remember a certain genius member calling your product "snake oil" and saying that your attention to detail on rocker geometry offers no benefit, I wonder what his view would be on this specific application.
Re: Another Edelbrock Victor Saga [Re: BradH] #1835278
05/27/15 02:41 PM
05/27/15 02:41 PM
BradH Offline
BradH  Offline
Oh, don't forget to drill & tap the center stud location to accept the longer studs like in the #2 & #4 shaft hold-down positions. There have been a number of center pedestal cracking reports on here, and I wouldn't run a Victor head w/o this mod now. twocents
